Glowing Hot Filter?
Glowing Hot Filter? Hoot 10 Oct 07:03
  Glowing Hot Filter? rich404 11 Oct 13:09
   Glowing Hot Filter? rich404 11 Oct 13:10
    Glowing Hot Filter? Hoot 13 Oct 02:16
    Glowing Hot Filter? ywho 08 Nov 04:30
  Glowing Hot Filter? SimoneRodriguez 15 Jun 14:04
2018-10-10 07:03:34 UTC (over 6 years ago)
Glowing Hot Filter?
I'm loving Gimp 2.10 but missing one of my favorite filters, Glowing Hot. Is there an add-on to get it back? Thanks for any help!
2018-10-11 13:09:21 UTC (over 6 years ago)
Glowing Hot Filter?
Some old Gimp resources, including scripts are here: Looks daunting but there is nothing much to do.
Go to the scripts section, click on the scriptyou want and it is shown with line numbers. You do not want the line numbers. The script will not work with line numbers.
Right click on the RAW button, then (depends on web browser) download link. That downloads the scm. Put that in your Gimp 2.10 User profile for Windows usually
C:\Users\your-name\AppData\Roaming\GIMP\2.10\scripts
Find it in the usual places File -> Create -> Logos and Filters -> Alpha-to-Logo
In case you stumble with the download, script attached.
2018-10-11 13:10:36 UTC (over 6 years ago)
Glowing Hot Filter?
Forgot the URL
https://github.com/GNOME/gimp-data-extras/
2018-10-13 02:16:14 UTC (over 6 years ago)
Glowing Hot Filter?
Thank you very much for that Rich404! Much appreciated!
2019-06-15 14:04:29 UTC (almost 6 years ago)
Glowing Hot Filter?
I do not know, why you see a lot of variants on your own with the help of these guys. But what if the connection with the descriptions here https://edubirdie.org/ are made on your own? It is better to work on it further.
ywho
2019-11-08 04:30:25 UTC (over 5 years ago)
Glowing Hot Filter?
Forgot the URL
well, that's awesome
ywho (via www.gimpusers.com/forums)
