Clouds filter
Clouds filter Mike Thorn 16 Jul 20:43
  Clouds filter Sven Neumann 16 Jul 22:06
Clouds filter Mike Thorn 16 Jul 22:35
  Clouds filter Jeff Trefftzs 16 Jul 23:22
Mike Thorn
2003-07-16 20:43:48 UTC (over 21 years ago)
Clouds filter
When I used 1.2.4 there was a pluginto make sky patterns with. It had colorpickers for things like clouds, shadows, sun, horizon, etc. That was all well and good, but I can't find it now in 1.2.5 and of course now I want it. What happened to it? Was it taken out and made into an optional plugin? Or did I miss something?
2003-07-16 22:06:44 UTC (over 21 years ago)
Clouds filter
Mike Thorn writes:
We didn't take any plug-ins out in the 1.2 series nor did we add any. We also did not move any plug-ins or scripts in the menus.
Mike Thorn
2003-07-16 22:35:52 UTC (over 21 years ago)
Clouds filter
Sven Neumann wrote:
Mike Thorn writes:
Hmm, very odd. Actually, I was using the windows port or 1.2.4. Does that matter?
It was listed under Filters | Render | Clouds.
Thanks for the help,
Jeff Trefftzs
2003-07-16 23:22:38 UTC (over 21 years ago)
Clouds filter
On Wed, 2003-07-16 at 13:35, Mike Thorn wrote:
Mike Thorn writes:
The plug-in was always an add-on. It would have been installed in /usr/local/lib/gimp/1.2/plug-ins/phymodmedia (at least on a Linux system) so you may need to reinstall it.
Good luck,
