Scripting for resize
Scripting for resize Paulo J Matos 16 Jul 17:10
  Scripting for resize Sven Neumann 16 Jul 18:14
   Scripting for resize Sven Neumann 16 Jul 18:20
   Scripting for resize Marc) (A.) (Lehmann 16 Jul 22:26
Scripting for resize Mike Thorn 16 Jul 18:08
Paulo J Matos
2003-07-16 17:10:18 UTC (over 21 years ago)
Hi all,
I'm just new to script-fu and gimp. I was not aware scheme is used for scripting in gimp. I loved that. :D Anyway, I've read the script-fu part of the gimp manual. I have a directory tree with about 1000 images and I'd like to resize them all to 20x20. Is there any script for doing that? If not, I checked the DB browser and I found out I need to use gimp-image-resize. How can I check which files are in a given directory?
Best regards,
Paulo J. Matos
Mike Thorn
2003-07-16 18:08:53 UTC (over 21 years ago)
Paulo J Matos wrote:
Hi all,
Paulo,
I've used David's Batch Processor (DBP) with great results. It also affords some extra options such as sharpening, blurring, changing color options, changing contrast, etc. It's quite a nifty little plugin. Anyway, it's available here:
http://members.ozemail.com.au/~hodsond/dbp.html
HTH,
2003-07-16 18:14:53 UTC (over 21 years ago)
"Paulo J Matos" writes:
for i in '*.png'; do convert -sample 20x20 $i > small-$i; done
Not a GIMP script but probably a lot better suited for this job.
2003-07-16 18:20:41 UTC (over 21 years ago)
Sven Neumann writes:
That should have read
for i in '*.png'; do convert -sample 20x20 $i small-$i; done
and it might still be wrong but I guess you got the idea anyway.
Marc) (A.) (Lehmann
2003-07-16 22:26:08 UTC (over 21 years ago)
Sticking a "!" at the end of the "20x20" will actually do the job.
