stegano compile problem
stegano compile problem Bill Winegarden 14 Jun 23:17
  stegano compile problem Sven Neumann 16 Jun 12:04
Bill Winegarden
2003-06-14 23:17:39 UTC (almost 22 years ago)
Hi Everyone,
My apologies to Sven on this one. I automatically hit reply and sent a private message regarding this list item. That was not my intention at all.
Thanks for the work in this patch. When I tried to apply the patch this is the process I followed. I saved the code in your email as stegano.diff and applied the patch using the command you supplied. This information was returned.....
[bill@localhost Stegano]$ patch -p0 < stegano.diff patching file stegano.c
Hunk #3 FAILED at 57.
Hunk #4 succeeded at 83 with fuzz 1. Hunk #6 FAILED at 134.
Hunk #8 FAILED at 161.
Hunk #9 FAILED at 174.
Hunk #10 FAILED at 191.
5 out of 13 hunks FAILED -- saving rejects to file stegano.c.rej
I have no knowledge of the coding itself so I return it to you in hopes that it makes some sense. If required, I can send the printout of the stegano.c.rej file, it is only about 3.2 kb.
Also, to others that responded, thanks.
Regards, Bill W.
2003-06-16 12:04:14 UTC (almost 22 years ago)
Bill Winegarden writes:
no problem, but please understand that I prefer to keep the discussion on the list.
You are obviously trying to compile a different version of the plug-in. I gave you the URL from where I downloaded the version I based the patch on. Please try that version instead.
