Question on Gimp and Phostoshop
| Question on Gimp and Phostoshop | Corrado Topi | 08 May 16:25 |
| Question on Gimp and Phostoshop | Sven Neumann | 08 May 16:30 |
| Question on Gimp and Phostoshop | Corrado Topi | 08 May 17:26 |
| Question on Gimp and Phostoshop | Carol Spears | 08 May 18:05 |
| Question on Gimp and Phostoshop | John Culleton | 08 May 18:08 |
| Question on Gimp and Phostoshop | Corrado Topi | 08 May 18:57 |
| Question on Gimp and Phostoshop | Jakub Steiner | 09 May 17:56 |
| Question on Gimp and Phostoshop | Carol Spears | 09 May 19:38 |
| Question on Gimp and Phostoshop | John Culleton | 09 May 20:03 |
| Question on Gimp and Phostoshop | Sven Neumann | 09 May 20:20 |
| Question on Gimp and Phostoshop | Jakub Steiner | 09 May 21:15 |
| Question on Gimp and Phostoshop | Tom.Williams@diversifiedsoftware.com | 09 May 00:48 |
| Question on Gimp and Phostoshop | zeus | 09 May 05:22 |
Hy all.
I would like to know if it is possible to save in Photoshop format.
If not, it is anyone working on a Photoshop export filter?
We would like to use Gimp here at the University for our courses in Multimedia, but we need this functionality (lecturers, who teach the subject, require this functionality. They are interested in using Open Source.).
I am using Gimp version 1.2.3 on Mandrake 9.1.
Thanks in advance.
Corrado Topi writes:
There is a PSD save plug-in available at registry.gimp.org. Latest GIMP-1.3 releases even include this plug-in already.
Thank for answering so quickly!
Do you know if there is a rpm of this patch? I have been looking around (rpmseek.com, rpmfind.net, mandrake mirror), and I have not found it ...
prolly there is no patch, and iirc, the version at the registry does not build without some twiddling. i have a binary available. i built this binary on debian woody, sometime ago. maybe it will help:
http://carol.gimp.org/gimp/plug-ins/
On 2003-05-08 at 1626.34 +0100, Corrado Topi typed this:
Any Linux system can use files in zip, gzip etc. formats. An RPM wrapper around the zipped file may be a convenience, but certainly is not a necessity. And the plugin in question is probably not even zipped. Just download and install.
It has always perplexed me that those who escape the limitations and expense imposed by commercial software nevertheless feel constrained to download only rpm files. Trust me, the other formats work just fine on your system. They are universal.
John Culleton
_____________
Thanks for the technical explanation. Our system administrators need to have rpm, because they need to install on huge numbers on workstations on networks, and they also need to have a clear map of the packages installed, dependencies versions and finally they need an easy-to-use upgrade/uninstall tool. So rpm/urpmi or dpkg/apt-get.
Did anyone package it in rpm?
Does the current PSD save plug-in support PhotoShop 6 or later PSD files?
Peace...
Tom
Sven Neumann Sent by: To: c.topi@hud.ac.uk gimp-user-bounces@lists.xcf.b cc: gimp-user@lists.xcf.berkeley.edu erkeley.edu Subject: Re: [Gimp-user] Question on Gimp and Phostoshop 05/08/2003 07:30 AM
"Our mission is to help our clients achieve more cost-effective data center operations."
I think it's based on PSD 4.0
Peace...
Tom
05/08/2003 07:30 AM
V ?, 08. 05. 2003 v 18:08, John Culleton napsal:
Well the difference is that an rpm archive doesn't just hold a bunch of files. It contains dependency information as well. Installing software outside the package database system brings along future dependency problems and makes it hard to track what is installed and what isn't.
However plugins are usually shipped along the core gimp package, I haven't seen a distro that would ship them separately. Searching for a PSD-save plugin rpm is probably not gonna get you anything.
However you can install gimp plugins as a user, to your home directory (~/.gimp-1.2/plugins) which will make box admins happy and you'll get the functionality you need. Just grab the tarball of theplugin from registry.gimp.org and install according to the supplied instructions (or see `man gimptool`).
cheers
On 2003-05-09 at 1756.30 +0200, Jakub Steiner typed this:
sometimes you need to ask your software management (like redhat or debian) for the developer version, which contains the gimptool.
"apt-cache search libgimp" i think is the quickest way to find this package with debian. dunno about redhat.
Dependencies are usually handled when you compile a new package. First one runs ./configure and then make. What value rpm adds to this process I don't know.
I generally can remember that I have Gimp installed. :-) If I want to know the version I can just fire it up and read the splash screen. If I want to know is package foo is installed I can do locate foo or even foo --help. I will find out in a hurry if it is there or not.
Maybe I am living in a dream world but I have been using Linux for many years without any rpm usage (except to unpack an rpm that is not available in any other form.) Slackware has its own package registry but I don't bother with it after initial install.
Agree! I cannot believe that the rpm management tool has so many defenders on the Gimp list, since Gimp itself is not available as an rpm AFAIK.
John C.
_____________
John Culleton writes:
That is surely the hard way. GIMP has quite a few dependencies that pull in even more dependencies. If you install it from RPM or from a debian package, all these libraries will be installed without you specifying them explicitely. This is a major advantage.
The GIMP developers decided to not try to distribute any binary packages. This is however not because we dislike the idea of package management. We simply lack the resources to build packages for all platforms and all distributions. Distributors can do a better job at building the GIMP packages the users need.
V P? 09. 05. 2003 v 20:03, John Culleton napsal:
I apologise to the rest of the list for this last email on this topic although it has little to do with GIMP. I think John is confusing some of the newbies here.
A proper package mangement won't let you remove a package others would depend on. I'm guessing you work on a Slackware distro, otherwise you'd see the distinction between a tarball and a package.
With a package system you can remove a piece of software and be sure no files are left behind. At any point of time you can see what package a particular file you see belongs to. You can ckeck what packages make use of a library. You can install applications without headers and other development cruft a typical user wouldn't need.
All I'm saying rpms,debs and other packages used with a package management software are a different league to source tarballs.
There ya go. Folks like you don't see the advantages of a package system and even see it as an unnecersary obstuction. I strongly disagree with you. There are drawbacks, but a proper package management system makes it possible to maintain a clean installation over time.
Almost every linux distribution ships packages of GIMP. There's many rpm and dpkg-based distributions out there.
cheers
