how to
10 of 10 messages available
Script-Fu: Text in a transparent image Cismaru Nicolae 16 Apr 02:16
  Script-Fu: Text in a transparent image Hago Ziegler 16 Apr 10:53
   how to sam ende 16 Apr 13:28
    how to Hago Ziegler 16 Apr 15:04
     how to Malcolm Turnbull 16 Apr 16:14
     how to sam ende 16 Apr 17:41
    how to Guillermo S. Romero / Familia Romero 16 Apr 16:25
how to Tom Williams 16 Apr 16:37
  how to Guillermo S. Romero / Familia Romero 16 Apr 17:28
  how to sam ende 16 Apr 17:44
Cismaru Nicolae
2003-04-16 02:16:25 UTC (about 22 years ago)
My name is Nicu Cismaru and I am a new user of GIMP. I want to create a script that will generate a transparent gif with my email address. The parameters of the script should be the font and the color. I am using WinGIMP v1.2.3. I have tried to create a script based on the example Michael Terry gives in its tutorial but I got stucked. I make an image (gimp-image-new), a layer for the image (gimp-layer-new) and a layer for the text (gimp-text-fontname). I resize the image to the dimensions of the text but I do not know what I should do next as this is the first script I am working at. Thank you for your time, NicuProtect your PC - Click here for McAfee.com VirusScan Online
Hago Ziegler
2003-04-16 10:53:17 UTC (about 22 years ago)
Hi Nicu,
I want to create a
Below you find a script, which makes a RGB-image with transparent background. I also tried it once with Mike Terrys totorial. I tried to convert it to INDEXED, but the output is quite ugly.
Regards, Hago
(define (script-fu-text-box1 inText inFont inFontSize inSpiel inTextColor) (set! theImageWidth 10)(set! theImageHeight 10) (set! theImage (car (gimp-image-new theImageWidth theImageHeight RGB) ) ) (set! theLayer (car (gimp-layer-new theImage theImageWidth theImageHeight 0 "layer1" 100 0) ) ) (gimp-image-add-layer theImage theLayer 0) (gimp-layer-add-alpha theLayer)
(gimp-palette-set-foreground inTextColor) (gimp-selection-all theImage)
(gimp-edit-clear theLayer)
(gimp-selection-none theImage)
(set! theText (car (gimp-text theImage theLayer 0 0 inText 0 TRUE inFontSize 0 "*" inFont "f" "*" "*" "*" "*" "*") ) )
(set! theImageWidth (car (gimp-drawable-width theText) ) ) (set! theImageHeight (car (gimp-drawable-height theText) ) ) ;(set! theBuffer (* theImageHeight (/ inSpiel 100) ) ) (set! theImageWidth (+ theImageWidth inSpiel inSpiel) ) (set! theImageHeight (+ theImageHeight inSpiel inSpiel) )
(gimp-layer-set-offsets theText inSpiel inSpiel)
(gimp-image-resize theImage theImageWidth theImageHeight 0 0) (gimp-layer-resize theLayer theImageWidth theImageHeight 0 0) (gimp-image-merge-visible-layers theImage 0) ;(gimp-convert-indexed theImage 0 0 255 1 1 "blah") (gimp-display-new theImage)
(cons theImage (cons theLayer (cons theText () ) ) )
(script-fu-register "script-fu-text-box1" _"/Xtns/Script-Fu/Text/Text Box1" "Erstellt eine einfache TextBox." ""
"RGB"
SF-VALUE "Text:" "\"Text Box\"" SF-VALUE "Font:" "\"Arial\"" SF-VALUE "FontSize:" "45" SF-VALUE "Spielraum:" "20" SF-COLOR "TextColor:" '(255 0 0) )
sam ende
2003-04-16 13:28:49 UTC (about 22 years ago)
how to
say you've already got gimp open and then you open a picture you got sent and you tell it to open with gimp, so then it opens another instance of gimp, which is silly. how do you get pictures to open in the already mounted gimp ?
sammi
Hago Ziegler
2003-04-16 15:04:08 UTC (about 22 years ago)
how to
Try File -> Open
Hago
Malcolm Turnbull
2003-04-16 16:14:05 UTC (about 22 years ago)
how to
Hago Ziegler wrote:
Try File -> Open
Ho.ho... :-)
This is a problem that really bugs users(idiots) at my company, they hate this feature of win-gimp (because of the slow start up times).
Malcolm Turnbull.
Crocus.co.uk Ltd 01344 629629
http://www.crocus.co.uk/
2003-04-16 16:25:37 UTC (about 22 years ago)
how to
sam@sende.freeserve.co.uk (2003-04-16 at 1228.49 +0100):
To contact an already launched gimp use gimp-remote, not gimp. Use -n param if you want to make it run a new one if none is running.
GSR
Tom Williams
2003-04-16 16:37:12 UTC (about 22 years ago)
how to
GSR
I believe, on Windows, drag-and-drop works so you _should_ be able to drag an image to the toolbox and drop it and it will open in the currently running Gimp. I think I've done that before, but I just don't remember. :)
Peace...
Tom
2003-04-16 17:28:46 UTC (about 22 years ago)
how to
tomdkat@attbi.com (2003-04-16 at 0737.12 -0700):
In other OSes too, but on some cases you have GIMP opened in some other place, away. You can DnD other things to other places (layers to make new images, layers to other images...). But some people do not like DnD at all.
GSR
sam ende
2003-04-16 17:41:48 UTC (about 22 years ago)
how to
On Wednesday 16 April 2003 14:04, Hago Ziegler wrote:
Try File -> Open
duh, are you not understanding, if it's attched to a mail, for instance or am i missing something ?
sammi
sam ende
2003-04-16 17:44:22 UTC (about 22 years ago)
how to
i'm on debian k6.
sammi
