Tutorial: Orb-Icons for Websites
Written by · Created on Mar 18, 2007, last updated almost 13 years ago CC BY-NC License
Of course you know these small little icons which can be often seen all around the web that look like a small glossy orb. Pretty nice to enhance also your personal website with it!
    Create a new file: 250×250px. Fill the background with #828282.
    Take the Elliptical Selection-Tool and create an exact circle. After that create a new empty layer, take the Gradient-Tool (L). As a FG-color choose #571f00, for the BG-color choose #ff5a00.
    Now draw a gradient from top to the bottom of that layer.
    The selection should still be active.
    Again create a new layer. Fill it black. To do this very fast first press D then press CTRL+,
    Now follow these steps:
    - Select / Shrink: 1px
    - Select / Feather: 100px
    After that press DEL two times to delete the selected part.
    Activate the layer that contains the gradient.
    Go to Filter / Licht & Shadow: Drop Shadow. X/Y: 0/0, Tranparency: 60%.
    Activate the layer that contains the gradient. From the context-menu of the layers-dialog choose “Alpha to selection”.
    Add a new layer. Choose white as FG-color. Take the “Gradient-Tool”. In the preferences-box of this tool choose the fourth option in the drop-down-menu for the gradients: “FG to Trasparent”. Apply this gradient from top to bottom.
    - Select / None
    - Activate the Scale-Tool
    - Click the layer, when the popup-menu appears enter 175 as width and 150px for the new height. Click OK.
    Take the Move-Tool now and move the white shine (the gradient ;)) to the top in the upper center of the sphere.
    Go to Filter / Blur / Gaussian Blur: Value: 5.
    We’re almost done. Now you can add for example a single character or any small symbol you want.
    I took the Text-Tool and simply wrote a question-mark “?” in white color into the middle of the orb. Then i chose “Grain extract” from the layers-mode drop-down.
    Thats it! Have fun with your new orbs ;)
This topic (Orb-Icons for Websites) has been rated 5.0/5.0.
AllstarSeaworthyofNBC member for over 9 years AllstarSeaworthyofNBC 4 comments rated this topic with 5/5
over 9 years ago
Wow... I loved this one. This is a information icon in green Written it DIN Neuzeit Grotesk.
almost 13 years ago
You can download it now in the tutorial details - must have missed the upload - sorry. Have fun!
Luke
almost 13 years ago
Insert the xcf file
Luke
almost 13 years ago
It's so hard
NR
over 13 years ago
Grain extract doesn't work :( The text becomes darker, why is that?
Cheesedude
over 15 years ago
*sigh* I can't get the tutorial to work. Split-Visionz's orbs are off center, the left side is not rounded. I guess I can't win around here. Thanks anyway!
Cheesedude
over 15 years ago
I'll have to try Split-Visionz scripts because this does not work for me. The problem is on Step 5.
Where it says:
Add a new layer. Choose white as FG-color. Take the "Gradient-Tool". In the preferences-box of this tool choose the fourth option in the drop-down-menu for the gradients: "FG to Trasparent". Apply this gradient from top to bottom.
What kind of layer? I assume transparent, because you can't do a white to transparent gradient on a white filled layer. At least my version of Gimp 2.6.7 won't.
Chobicus rated this topic with 5/5
over 15 years ago
Very nice tut.
ddjj
over 16 years ago
Nice. Rather than say something like, "Activate the layer that contains the gradient", give each layer a
name and refer to that name. I was a little confused
at times, what layer I should be manipulating. From Step 9, it appears meaningful names were given at some time.
Thx
Matt
over 16 years ago
Brilliant tutorial, especially on how to get a border round the orb
ShockwaveLover member for almost 17 years ShockwaveLover 7 comments
over 16 years ago
Another brilliantly useful tutorial.
@agcilantro - The Alpha to Selection function allows you to retain a selection while you create a new layer. This may not seem like much use, but it means that you can create exact duplicates of what ever it is that is selected. Making shadows is very easy this way.
Simply right click the layer you want, click 'Alpha to selection', create a new layer, then drag the colour or gradient you wish to apply over the selection. Apply any filters, and there you go.
agcilantro
over 16 years ago
Thanks for the great tutorial
Can you please explain what the selection to alpha does? It is the only step that I don't understand.
Zeke
over 16 years ago
What about exporting it to svgz?
Butterfly
over 16 years ago
I would also like to hint that if you're not looking for such a pronounced "shine" You should mess around with the Gaussian Blur and maybe put to something like 20. That worked out a lot better for me =D
Butterfly
over 16 years ago
I would like to tell devvv thank you so much for this tut. I've been looking for something like this for a while. And to that visionz guy thanks so much.. No if I could just find a way to make a nice bubble i would be in heaven :P
Desert
about 17 years ago
Just save the file as *.bmp, gimp will automatically (at least mine does) as a bitmap
jimmycrackcorn
about 17 years ago
how do i save this as a bitmap? i need just the button with a transparent background for a project so i can put this button overtop of another image. thanks for the help. great tutorial!
Desert
about 17 years ago
In linux it's located in /home/YOUR_USERNAME/.gimp? where the ? is your version of gimp.
Hope it helped you.
stalepretzel
over 17 years ago
Thanks for the tutorial!
I've wanted to makes some Web-2.0-looking graphics for some time, now, but I was unable; I only had Photoshop Elements. That's problematic because:
1) It was on the Windows computer, not the Mac that's much easier to use, and,
2) Almost all Photoshop Tutorials use CS, often relying on tools that weren't available in elements.
Then GIMP came along!
Free, easy, and it comes with a comunity of other GIMPers making tutorials for the same version I use!
Thanks again for the tutorial!
Ztoph member for almost 18 years Ztoph 4 comments
over 17 years ago
I Could never dream of using windows.
its a fucking shit OS.!!
But thanks. Now i just gotta find the folder.
Split-Visionz member for almost 18 years Split-Visionz 3 comments
almost 18 years ago
You put the files in the gimp scripts folder, there are two folders you can use...
1.
documents and settings> user_name >.gimp2.4> scripts
If you put it in that folder only the account who user_name refers to can use them or...
2.
C:>Program Files>GIMP-2.0>share>gimp>2.0>scripts
all accounts on the pc can use them if you place them there... Also to note... what i said is for Windows only and the scripts folder may be located somewhere else on linux or Mac...
Also I created a gelbar script you might be interested in....
http://www.gimptalk.com/forum/topic/Gelbar-Script-Pack-26975-1.html
Even though its not my tutorial, in my opinion it is sometimes better to through on generic background layer on images so you can fully view things such as the shadow or edge of something your cutting which is sometimes not noticeable on gimps checkerboard BG it uses to symbolize transparency.
almost 18 years ago
Nice tut, but wouldnt it be better with a transparent bg? then you could put it on anything
And a little question to Split-Visionz:
How do i install that script?
almost 18 years ago
the result of step five should be a gradient that is white at top and transparent at bottom. if you have other detailed questions please just ask
Gimpwarrior member for almost 18 years Gimpwarrior 1 comment
almost 18 years ago
i got lost at step five
almost 18 years ago
Sorry, I guess I didn't post the link. lol.
Here:
http://split-visionz.net/Scripts/GlossOrbScript%20Pack%20version%201.zip
almost 18 years ago
very cool ;) but where do we get it?
almost 18 years ago
I created a Gimp Script based off of this tutorial that will create the orbs. You can get it at:
cemkalyoncu
about 18 years ago
Great.
When I use gain extract I get a black text with some tinting on it. Instead I used gain merge and it looks fine.
over 18 years ago
you can simply try rectangle shapes or any other shape, the steps remain pretty much the same.
Mirat Bayrak
over 18 years ago
Can you show it with another shape? with rectangle or something else
over 18 years ago
hey peter! i don't know exactly what you mean. but only the preview of the pictures are saved as jpg, the full size is lossless png.
Peter Grosse
over 18 years ago
Dude , nice tut , but never save images as jpg , unless you computers memory is like 64mb.
kyle87
over 18 years ago
This tutorial is very cool
