USB scanner, Xsane and Gimp
USB scanner, Xsane and Gimp Nigel Ridley 17 Feb 20:37
  USB scanner, Xsane and Gimp Fred Bazolo 17 Feb 20:58
USB scanner, Xsane and Gimp Tom Williams 17 Feb 21:00
  USB scanner, Xsane and Gimp John Culleton 17 Feb 21:56
Nigel Ridley
2003-02-17 20:37:55 UTC (about 22 years ago)
Hi all,
I know this isn't exactly Gimp stuff - but I am trying to access my new USB scanner through the Gimp:
File -> Acquire -> Xsane: Device dialog and I figured that lots of you guys must have already set up a USB scanner :-)
Anyway, I've done a lot of google-ing but so far have been unable to find out how
to set it up.
When I re-booted the system (I installed a new sound card - SBLive [which I'm still trying to get working]) the usb modules loaded ok and I have an entry /dev/usb/scanner0 (-rw-rw-rw-). However, when I try to access it from within the Gimp (or thru Xsane), I get an error message that no devices are available.
I did do a 'sane-find-scanner -v' and got the following: sane-find-scanner: checking /dev/usb/scanner0... open ok, vendor and product ids were identified
sane-find-scanner: found USB scanner (vendor = 0x04a5, product = 0x20b0) at device /dev/usb/scanner0
Do I have to mount the scanner first- if so what do I put in /etc/fstab? Or is it that I have to make the system think that it is a scsi device?
Any pointers welcome :-)
Blessings,
Nigel
I AM Bible Studies and Resources http://www.i-amfaithweb.net
Messianic E-Cards.com http://www.messianicecards.com
OliveRoot Ministries http://www.oliveroot.net
Fred Bazolo
2003-02-17 20:58:12 UTC (about 22 years ago)
On Monday 17 February 2003 11:37, Nigel Ridley wrote:
Hi all,
to set it up.
Blessings,
Nigel
what brand of scanner, what version of linux, what version of GIMP, etc ?
Tom Williams
2003-02-17 21:00:41 UTC (about 22 years ago)
Nigel Ridley wrote:
Hi all,
to set it up.
Blessings,
Nigel
First, you have to get your scanner working under XSane. This problem is not a GIMP problem and I'm willing to work with you on this offline. I have a HP ScanJet 5200C (USB) that I use with GIMP and XSane without problems. I also encountered the same problem you did and WAS able to get it resolved through XSane configuration changes.
E-mail me your scanner make/model and we can go from there.... :)
Peace...
Tom
John Culleton
2003-02-17 21:56:41 UTC (about 22 years ago)
On Monday 17 February 2003 20:00, Tom Williams wrote:
Nigel Ridley wrote:
Hi all,
to set it up.
Here is my setup.
The xsane program is linked into /usr/local/lib/gmp/1.2/plugins directory.
There is a necessary file called /usr/local/etc/sane.d/epson.conf
An important line in this file says: usb /dev/usbscanner
The actual device file is: crw-rw-rw- 2 root root 180, 48 Mar 25 2001 /dev/usbscanner
When I boot I get these messages (try dmesg | less to examine yours)
usb.c: registered new driver usbscanner scanner.c: USB Scanner support registered.
As the others said, let us have all the gory details. I have an Epson Perfection 1240U.
HTH
