"Knitting" Images?
2 of 3 messages available
"Knitting" Images? Terry Hancock 17 Jan 07:09
02de01c2bdf0$903e5500$66c8a... 07 Oct 20:15
  "Knitting" Images? Terry Hancock 17 Jan 08:07
Terry Hancock
2003-01-17 07:09:29 UTC (over 22 years ago)
"Knitting" Images?
A long, long time ago, in a graphics package far, far away ...
There was a utility, which I think was called "knit" which would correlate two images, look for an overlap region and use the result to composite them into a single image. The application, of course, was putting together multiple scans or photos of the same original when the scanner or FOV was too small to capture the whole.
Does Gimp have any equivalent to that and/or is there an external program that I can use (on Linux) to do it? Also, is there a more appropriate term for it, because "gimp knit images" does not turn up anything too appropriate on Google. :-)
Thanks for any pointers, Terry
Terry Hancock ( hancock at anansispaceworks.com ) Anansi Spaceworks http://www.anansispaceworks.com
Terry Hancock
2003-01-17 08:07:09 UTC (over 22 years ago)
"Knitting" Images?
On Thursday 16 January 2003 10:20 pm, Kevin Myers wrote:
You might also search for image "stitching" which I think is the more commonly used term.
Thanks! That's all it took (I probably misremembered the original name) -- I found "grunch" which is available in Debian, and at the upstream site: http://www.radagast.org/~dplatt/unix/
Some other options were at this digital photography site: http://www.geocities.com/piccolbo/dplinux.html
Thanks for the help! Terry
"Some things are too important to be taken seriously"
