Mass Conversion
Mass Conversion Joseph A Nagy Jr 05 Nov 07:04
Mass Conversion David Hodson 05 Nov 13:41
Mass Conversion Geoffrey 05 Nov 14:42
Mass Conversion Joseph A Nagy Jr 05 Nov 17:03
Joseph A Nagy Jr
2002-11-05 07:04:30 UTC (over 22 years ago)
Mass Conversion
Hi all,
I'm on RH7.2 using Gimp 1.2.3 (waiting for that Gimp 1.3.x RPM to come out) and I want to convert every last jpg and bmp on my computer to and RGB png. Is there already a script out there to do that? If so, I haven't been able to find it via google or Gimp.org. TIA!
David Hodson
2002-11-05 13:41:10 UTC (over 22 years ago)
Mass Conversion
You could try my batch plugin at: http://members.ozemail.com.au/~hodsond/dbp.html
Geoffrey
2002-11-05 14:42:10 UTC (over 22 years ago)
Mass Conversion
Hi all,
Check out ImageMagick, it can do cli conversion like:
!#/bin/ksh
#converts all files named *.jpg and *.bmp to png format and names the #new file *.png
for $(find . \( -name '*.jpg' -o -name '*.bmp \) -print); do
convert $fn ${fn%.???}.png done
Joseph A Nagy Jr
2002-11-05 17:03:29 UTC (over 22 years ago)
Mass Conversion
Hi all,
!#/bin/ksh
Thanks all, I just downloaded the batch conversion plug-in for GIMP.
