building gimp in solaris
building gimp in solaris Louis Rayman 29 Oct 20:54
building gimp in solaris Kevin Myers 30 Oct 01:40
Louis Rayman
2002-10-29 20:54:24 UTC (over 22 years ago)
I'm trying to build gimp 1.3.9 on solaris 5.8
I've already built gtk+ 2.0.6 and its sub-libs, they are installed in a "non-standard" location, pointed to by $USRLOC
I'm running the gimp configure like this: $ CPPFLAGS=-I$USRLOC/include LDFLAGS=-L$USRLOC/lib ./configure --prefix=$USRLOC
the output complains that it can't find gnome-config:
... found xgettext program is not GNU xgettext; ignore it checking for catalogs to be installed... ca cs da de el en_GB es fi fr ga gl hu hr it ja ko nl no pl pt pt_BR ro ru sk sv tr uk zh_CN zh_TW checking for pkg-config... /local/u1/work/usrlocal/bin/pkg-config checking for GLIB - version >= 2.0.0... yes (version 2.0.6) checking for bind_textdomain_codeset... no checking for X... libraries /usr/openwin/lib, headers /usr/openwin/include checking whether -R must be followed by a space... no checking for gethostbyname... no
checking for gethostbyname in -lnsl... yes checking for connect... no
checking for connect in -lsocket... yes checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes checking for pkg-config... (cached) /local/u1/work/usrlocal/bin/pkg-config checking for GTK+ - version >= 2.0.0... sh: gnome-config: not found sh: gnome-config: not found
no
*** Could not run GTK+ test program, checking why... *** The test program failed to compile or link. See the file config.log for the *** exact error that occured. This usually means GTK+ is incorrectly installed. configure: error: Test for GTK failed. See the file 'INSTALL' for help.
what am I doing wrong?
I'm attaching the config.log (compressed)
thanks!!
Kevin Myers
2002-10-30 01:40:34 UTC (over 22 years ago)
I believe the problem is that pkg-config can't find your gtk+. The gnome-config message is just a side affect. One way to solve this problem is to set a PKG_CONFIG_PATH environment variable pointing to the pkgconfig sugdirectories of each package that pkg-config will be used for. Below are some lines from a script that I used for building the gimp under Windows. I think you probably need something similar, but with your own solaris paths instead of my Windows paths. Perhaps there is some better/alternative way to solve this problem, but that's how I handled it.
s/KAM
export PKG_CONFIG_PATH=\ D:\\source\\gettext-dev-0.10.40-20020904\\lib\\pkgconfig\;\ D:\\source\\glib-dev-2.0.6-20020802\\lib\\pkgconfig\;\ D:\\source\\gtk+-dev-1.3.0-20020912\\lib\\pkgconfig echo PKG_CONFIG_PATH=$PKG_CONFIG_PATH
----- Original Message ----- From: "Louis Rayman"
To:
Sent: Tuesday, October 29, 2002 1:54 PM Subject: [Gimp-user] building gimp in solaris
no
for the
installed.
thanks!!
-- Lou
