rounded edges
2 of 3 messages available
20021017190103.D318B1F05E@l... 07 Oct 20:15
  Gimp-user digest, Vol 1 #473 - 4 msgs Shawn Lindsay 17 Oct 22:27
  rounded edges Shawn Lindsay 17 Oct 22:32
Shawn Lindsay
2002-10-17 22:27:09 UTC (over 22 years ago)
Message: 2
Subject: Re: [Gimp-user] rounded rectangle From: Daniel Haus
To: Gimp Users Mailinglist
Date: 16 Oct 2002 23:38:46 +0200
i guessed that, unfortunately almost none of the script-fus work with gimp-1.3 in my localized (german) gnome2-environment, because of some confusion about floating point numbers (in german it's "1,0" instead of "1.0" so i about always get error-messages). i've seen this bug is already reported. can this easily - until it's officially fixed - be corrected by a few hacks, or will this require some more work and knowledge about gimp's internals? did anyone make it work?
the tutorial at http://gug.sunsite.dk did it for me. it's not exactly how i'd like it, a better solution might be a "roundness" option in the rectangular-selection-property-tab, but at least, it works.
Can you choose select-->grow from the menu? If so, you can make a small rectangular selection on a huge background and grow it by a large number like 256 pixels. The result will be a rectangular selection with rounded edges.
Shawn Lindsay.
Shawn Lindsay
2002-10-17 22:32:27 UTC (over 22 years ago)
rounded edges
Forgive me, list. I forgot to change the subject line in that last post re Daniel's problems with rounded edges. To get rounded edges without script-fu:
1. make a small selection on a huge background 2. select-->grow; choose a huge number like 256 pixels 3. Voila. Well, depending on your processor, it may take a few seconds.
Shawn.
