using GIMP in batch mode
using GIMP in batch mode Luc NOVALES 29 Aug 16:57
using GIMP in batch mode Yanil 29 Aug 17:12
using GIMP in batch mode Yanil 29 Aug 17:24
Luc NOVALES
2002-08-29 16:57:11 UTC (over 22 years ago)
I am a newbee on this list, and with gimp 1.2.1 on Solaris 8. I have to convert a lot of colors images in greyscale, in another format, and ImageMagick have problems to open the original image (due to the size ?).
I would like to use GIMP procced it in batch mode. I know the sequence to apply in manual mode, but I can't make it in batch. I prefer use command line, rather than script or perl-fu, if it is possible
I didn't found any solution on this forum, in the user manual and at
Where can I find others exemples to understand the good way ?
Thank you for your help. Luc.
Yanil
2002-08-29 17:12:18 UTC (over 22 years ago)
I ussually convert files in xbm format to png format using this command:
gimp -i -b '(file-png-save 1 (car (file-xbm-load 1 "file.xbm" "file.xbm")) (car (gimp-image-active-drawable (car (file-xbm-load 1 "file.xbm" "file.xbm)))) file.png file.png 0 9 0 0 0 0 0))' '(gimp-quit 0)'
This executes two batches (each one between '): "file-png- save" to convert the file , and "gimp-quit 0" to exit gimp. See the specifications of the scripts to understand that command do, and ask me if you don't understand anything
Yanil.
P.S.: I'm sorry about my english, but I'm spanish speaker.
8.
another
the size ?).
the sequence
prefer use
manual and at
way ?
Luc.
Yanil
2002-08-29 17:24:21 UTC (over 22 years ago)
There is some sintax error in my message. The correct command is:
1 "file.xbm" "file.xbm")))) "file.png" "file.png" 0 9 0 0 0 0 0))' '(gimp-quit 0)'
See
command
Yanil.
Solaris
8.
another
the size ?).
the sequence
prefer use
possible
manual and at
good
way ?
Luc.
