Tutorial: Create a simple Grunge-Stamp!
Written by , translated by HostedDinner · Created on Dec 16, 2009, last updated over 14 years ago CC BY-NC License
This Tuturial shows you how to make a simple stemp, with a Grunge Effect.
    - Create a new picture (e.g. 650×650).
    - Choose a color for the stamp text, I have used a red one: #dd0000.
    - Now write a text using the text-tool
    Now we make the text look better by adding a border to it
    - Therefore add a new layer and activate it
    - Choose the Selection-Tool and drag a border. The distance to each side shoud be approximately the same to look asthetically.
    - Select / Border… (5px depending how thick the border shoud be)
    - Edit / Fill with FG Color
    - Select / None
    It should look like this:
    In this step we rotate the picture
    - right click the layer and choose “Merge down”
    - Choose the Rotate Tool and rotate the picture to a desired position
    Now we’re coming to the Grunge-Effect:
    - Layer / Mask / Add Layer Mask (White)
    - Choose Paintbrush (Brushtyp Confetti)
    - Reset the color to black (use D on your keyboard)
    - Paint at will on the Layer mask (Black becomes transparent, so it looks white)
    Second part of the noise:
    - Choose Ink Tool
    • Opacity: 70-80%
    • Size: 6
    • Typ: rhombus
    • Shape: thin, so you have to drag the pointer a little bit down
      - Paint again at will (sometimes a little bit faster and slower)
      - Opacity could be change for some strokes to 80-90%, so there is some variety in it
    We’re done! I hope you like your newly created stamp ;)
This topic (Create a simple Grunge-Stamp!) has been rated 4.5/5.0.
MOPM
over 3 years ago
State Department for Mining
P.O. Box 30009-00100
NAIROBI
Jiri
over 6 years ago
Thank you very much. You made my life easier.
Patrice
over 6 years ago
Thanks a lot, just in 3 minutes with your GIMP tuto I got my electronic "PAID" stamp.
Awesome!
Mega
almost 8 years ago
Thank you! Your lesson is the best!
Tommy
about 12 years ago
First I want to say I love GIMP! Great software! I have been using it for years and will never go back to photoshop. visit some of my world here http://www.tjg-designs.com
Noureddine
over 12 years ago
don't bother your self i found a soulution :p
Noureddine
over 12 years ago
thx for the great Tuto
am suks with " paint at well"
can recomnd a brush that can a that cool effect for me cuz i can't while using "paint at well "
thanx again :D
HAHA
over 14 years ago
Thx for teaching me. defiantly a must try! It looks so reals and it is easy to do.
Thx
GIMP Tuts rated this topic with 5/5
almost 15 years ago
amazing tut my friend its really good uploaded some of the ones i created to DeviantART :3
Tommy rated this topic with 4/5
almost 15 years ago
Thanks for this article.
www.TJG-Designs.com
Ray rated this topic with 5/5
almost 15 years ago
I have always wondered how to do this. (Never could find how to though, lol.) Thank you for your work :D!
wilson member for almost 16 years wilson 2 comments rated this topic with 4/5
about 15 years ago
Looks real. This one is a must try.
Thank you for the nice tutorial :)
Jose
over 15 years ago
Wow really nice, I tried a similar effect before with GIMP, but this one is much better!
aclim member for over 15 years aclim 2 comments
over 15 years ago
It look real stamp...
