Making Logos with no background
8 of 8 messages available
Making Logos with no background spu 20 Jul 16:22
  Making Logos with no background Nigel Ridley 20 Jul 19:12
  Making Logos with no background Joel 20 Jul 19:22
Making Logos with no background Geoffrey 20 Jul 17:24
  Making Logos with no background Nigel Ridley 20 Jul 19:09
Making Logos with no background Tom Williams 20 Jul 17:34
Making Logos with no background Tom Williams 20 Jul 19:26
Making Logos with no background spu 21 Jul 04:51
spu
2002-07-20 16:22:19 UTC (over 23 years ago)
Hello, all :)
How can I make logos with no background, so that the logo will appear to be right on top of the background, and not in the middle of a big white background. I looked around in "The Gimp" in the appropriate areas, and I could only see where it would allow me to choose the background color, not to omit the background entirely. All help on this matter will be greatly appreciated. The following links are two examples about the problem I am having:
http://www.faith4miracle.org/pages/Logos.html http://www.faith4miracle.org/pages/underconstruction.html
The main address is: http://www.faith4miracle.org
Thanks in advance for your help :) Steven P. Ulrick
Geoffrey
2002-07-20 17:24:49 UTC (over 23 years ago)
When you create a new image in gimp, one of the options is the type of background: foreground color, background color or transparent. Choose transparent. It's on the window that opens when you choose file->new option.
spu wrote:
Hello, all :)
Tom Williams
2002-07-20 17:34:00 UTC (over 23 years ago)
It looks like he was using "Script-Fu" to make logos when you do it THAT way (Xtns/Script-Fu/Logos) you don't have a way to have the plug-in create a transparent background for you, at least not with Gimp-1.2.3.
Peace....
Tom
spu wrote:
Hello, all :)
Nigel Ridley
2002-07-20 19:09:15 UTC (over 23 years ago)
spu wrote:
Hello, all :)
Nigel Ridley
2002-07-20 19:12:44 UTC (over 23 years ago)
On 20 Jul 2002 09:22:19 -0500
spu wrote:
Hello, all :)
Joel
2002-07-20 19:22:04 UTC (over 23 years ago)
It looks like you're creating "Glossy" style logos, from Xtns/Script-Fu/Logos/Glossy. For this particular type of logo, making the background transparent is float is pretty simple. To do it:
1: Create the logo, as normal 2: Go to your Layers, Channels, and Paths dialog box. The image should have four layers. The bottom-most layer is the background. Delete it (or hide it) and the background layer will be invisible. You could also merge the visible layers at this point (though don't flatten the image -- that'll put in a background color)
3: Save the image as a .gif or a .png. Right now, you're saving the file as a jpeg; those don't support transparency at all.
--Joel
Hello, all :)
Tom Williams
2002-07-20 19:26:37 UTC (over 23 years ago)
spu wrote:
Hello, all :)
spu
2002-07-21 04:51:07 UTC (over 23 years ago)
Thanks, everybody for your help :) Someone even sent me an example, and I also learned how to make logos without any background all by myself :)
Thanks again for all your help :)
Steven P. Ulrick
