layer move to fit other layer
layer move to fit other layer Zoran Bosnjak 13 Jul 17:50
Zoran Bosnjak
2002-07-13 17:50:45 UTC (almost 23 years ago)
I need a script that will move active layer to fit on the edge of another layer (the layers overlap on some area on the edges).
I could place the layer by hand close to the solution and the script should do the rest (find the maximum layer corelation for every offset inside specific range... and move one layer to that offset).
Is there a script that does this?
best regards, Zoran Bosnjak
