Question about GIMP 1.2.3 (or GIMP 1.3.7) and perl 5.8.0-RC1
Question about GIMP 1.2.3 (or GIMP 1.3.7) and perl 5.8.0-RC1 Tom Williams 08 Jul 08:45
Tom Williams
2002-07-08 08:45:28 UTC (almost 23 years ago)
Hi! Ok, I have gcc-3.1.1 (20020701 snapshot) installed on my Slackware Linux 8.0 system and perl 5.6.1 will NOT build "out of the box" with gcc-3.1, but perl 5.8.0 will. So, I installed perl 5.8.0-RC1 and then built gimp-1.2.3 and gimp-1.3.7.
I'm still encountering problems with gimp hanging X when I use certain features, mainly Script-Fu features (like making logos from Xtns->Script-Fu->Logos or using Perl-o-tine which uses Script-Fu and perl).
I gimp-1.2.3 or gimp-1.3.7 compatible with perl 5.8.0? I'm wondering if this is part of my instability problem. Most recently, when I use "Perl-o-tine" to "carve up" an image for a web page, I will see one or two windows from Perl-o-tine doing it's thing then desktop hangs. My mouse pointer still moves, but I can't click anything. Ctrl-Alt-F1 can be used to swtich to a console session that I can ue to kill gimp, but the ONLY way to get control back is to send a "HUP" to X, which resets everything. I'm running XFree86 4.2.0 with a NEW GeForce2 MX-200 PCI video card w/ 32 MB of RAM. I'm running on a Pentium II 350 MHz w/ 196 MB of RAM.
I'm not sure when the "stable" version of perl 5.8.0 will be released and I would like to know if the gimp is compatible with this version of perl...
Thanks! :)
Peace....
Tom
