Asking questions twice
3 of 5 messages available
mailman.1.1216839603.30619.... 07 Oct 20:19
  Gimp-user Digest, Vol 70, Issue 17 George Fishman 23 Jul 21:48
mailman.3.1217444405.2488.g... 07 Oct 20:19
  Gimp-user Digest, Vol 70, Issue 24 George Fishman 30 Jul 22:13
   Asking questions twice David Hodson 31 Jul 01:34
George Fishman
2008-07-23 21:48:05 UTC (almost 17 years ago)
Hello
I'm running the new Gimp package on OS 10.5.4. Thanks to all who are involved in its development.
As a mosaic artist and not a programmer, I am keen to know if there's a way to revive the "conical
anamorphose" filter that I understand was part of earlier versions. I would like to make a 3-d rendering of an image and then apply glass and stone to it.
Could anyone explain to a lay person how this filter could be added to the program -- if it can?
Thanks so much, George
On Jul 23, 2008, at 3:00 PM, gimp-user-request@lists.XCF.Berkeley.EDU wrote:
Send Gimp-user mailing list submissions to gimp-user@lists.XCF.Berkeley.EDU
To subscribe or unsubscribe via the World Wide Web, visit https://lists.XCF.Berkeley.EDU/mailman/listinfo/gimp-user or, via email, send a message with subject or body 'help' to gimp-user-request@lists.XCF.Berkeley.EDU
You can reach the person managing the list at gimp-user-owner@lists.XCF.Berkeley.EDU
When replying, please edit your Subject line so it is more specific than "Re: Contents of Gimp-user digest..."
Today's Topics:
1. IPTC data (Andrew) 2. Problem with psd files under Ubuntu (Heiko Schmidt)
Message: 1 Date: Wed, 23 Jul 2008 10:25:32 +0200 From: Andrew
Subject: [Gimp-user] IPTC data
To: gimp-user@lists.xcf.berkeley.edu Message-ID:
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Good day,
My workflow is: Pentax raw (.pef) > rawstudio > gimp > save as tif > add
iptc data with exiftool. If I then open the tif again in gimp I get the
following message:
wrong data type 7 for "XMLPacket"; tag ignored
and on saving again all the iptc data has gone.
Is there a solution to this?
TIA,
Andrew
Message: 2 Date: Wed, 23 Jul 2008 13:06:13 +0200 From: Heiko Schmidt
Subject: [Gimp-user] Problem with psd files under Ubuntu To: gimp-user@lists.XCF.Berkeley.EDU Message-ID:
Content-Type: text/plain; charset=ISO-8859-15; format=flowed
I'm currently not able to open psd files with Gimp. (SVN build under Ubuntu). During the process to opening the file the progress bar stops by ca 75%. With Gimp 2.4.5 the same. I can load all the those psd files
under Windows with Gimp 2.4.6.
Here is a stack trace. Maybe someone can help. Would be appreciated.
/home/heik/gimpSVN/lib/gimp/2.0/plug-ins/psd (pid:6734): [E]xit, [H]alt,
show [S]tack trace or [P]roceed: S
#0 0xb7efc410 in __kernel_vsyscall () #1 0xb76f98c3 in __waitpid_nocancel () from /lib/tls/i686/cmov/libpthread.so.0
#2 0xb7765965 in g_on_error_stack_trace () from /usr/lib/ libglib-2.0.so.0
#3 0xb7765e85 in g_on_error_query () from /usr/lib/libglib-2.0.so.0 #4 0xb7d94394 in gimp_plugin_sigfatal_handler (sig_num=11) at gimp.c:1539
#5
#6 0x0804c718 in add_layers (image_id=1, img_a=0xbf856374, lyr_a=0x8064000,
#7 0x0804e28f in load_image (
#8 0x0804a484 in run (name=, nparams=3, param=0x8062480,
#9 0xb7d94a78 in gimp_main (info=0x8053d10, argc=6, argv=0xbf856604) #10 0x0804a6da in main (argc=0, argv=0x0) at psd.c:59 /home/heik/gimpSVN/lib/gimp/2.0/plug-ins/psd (pid:6734): [E]xit, [H]alt,
Heiko
George Fishman
2008-07-30 22:13:53 UTC (over 16 years ago)
Is it considered proper to ask a question again if I've rec'd no response after a week or so?
Thanks, George
Today's Topics:
1. Re: Edit brushes bug? (Johnny Rosenberg)
Message: 1 Date: Wed, 30 Jul 2008 18:31:06 +0200 From: "Johnny Rosenberg"
Subject: Re: [Gimp-user] Edit brushes bug? To: " GIMP Anv?ndarforum GNU/Linux "
Message-ID:
Content-Type: text/plain; charset="utf-8"
David, I just realised that I accidently sent my last reply to you personally. I'm sorry for that. I am used to the OpenOffice.org mailing
lists, with which I can just click Reply to reply to the list automatically.
It seems like I can never get used to having to enter the address of the
list manually or click Reply to all and then remove all addresses except the
list's address.
2008/7/29 David Gowers
On Wed, Jul 30, 2008 at 12:21 AM, Johnny Rosenberg wrote:
Tried to edit the pre-loaded brushes, but they are displayed as Write
protected. I located the brushes in /usr/share/gimp/2.0/brushes and I
made
myself owner and I gave the files all rights and I even did that to the
folder itself (except I didn't change the owner of the folder).
Still, the brushes are write protected, so I can't, for example, rotate
them.
Set the folder as writeable in the GIMP folder preferences.
Okay, replied:
"I'm sorry to say this, but I couldn't find that. I found Folders ? Preferences but I couldn't see anything to change there, except that I could
and and delete search paths. I'm not sure I'm following?"
Actually, I meant that I found File ? Settings ? Folders (or if "settings"
should be replaced with "preferences", I have the Swedish version, so I am
not really sure).
However, David replied:
Folders -> Brushes
So here's my new reply:
If you mean File ? Settings ? Folders ? Brushes, I can't really see any
possibilities to set anything to writeable or even setting anything at all
to what ever, except that I can add and delete search patchs for the brushes. There are a few buttons, but they are all deactivated. The buttons
seems to be New, Up, Down, Delete and a green ?. -------------- next part -------------- An HTML attachment was scrubbed...
URL: /lists/gimp-user/attachments/20080730/2777b06a/ attachment-0001.html
David Hodson
2008-07-31 01:34:14 UTC (over 16 years ago)
If no one responds, it's possible that no one has an answer. However, perhaps you would get a better response if you trimmed your reply ...
... and followed instructions.
