using grid on gimp
using grid on gimp cabrio531@aol.com 12 Jul 20:56
  using grid on gimp David Gowers 13 Jul 01:15
  using grid on gimp saulgoode@flashingtwelve.brickfilms.com 13 Jul 06:34
  using grid on gimp Owen 13 Jul 12:29
cabrio531@aol.com
2008-07-12 20:56:19 UTC (almost 17 years ago)
using grid on gimp
I am trying to make 10 cm and 20 cm horizontal and vertical lines on a photo.? In other word, trying to divide a photo into thirds. Can someone help?? Thanks.
Ellen
David Gowers
2008-07-13 01:15:28 UTC (almost 17 years ago)
using grid on gimp
Hi Ellen,
You can select 'cm' as the unit in the grid configuration dialog. whether this does exactly the right thing is something you'll have to check yourself.
(personally, I would look at the pixel width and height, and divide them by 3. I'm not used to working in cm.)
The grid configuration dialog is found in the Image menu (Image->Configure Grid).
On Sun, Jul 13, 2008 at 4:26 AM, wrote:
I am trying to make 10 cm and 20 cm horizontal and vertical lines on a photo. In other word, trying to divide a photo into thirds. Can someone help? Thanks.
Ellen
2008-07-13 06:34:11 UTC (almost 17 years ago)
using grid on gimp
Quoting cabrio531@aol.com:
I wrote a Script-fu a while back which will create a 3x3 grid layer based upon the dimensions of either the current layer or the image. The grid is created on a new layer so you can remove it or hide as necessary.
The command is added to the menus under "Filters->Render-Pattern->Rule of thirds grid" and the code for the script is located at the following URL:
http://flashingtwelve.brickfilms.com/GIMP/Scripts/thirds-rule-grid.scm
Owen
2008-07-13 12:29:37 UTC (almost 17 years ago)
using grid on gimp
Ellen
Does Filters->Web->Slice help?
Owen
