batch mode in gimp, add alpha, change color
| batch mode in gimp, add alpha, change color | Choi, JiHui | 01 May 15:54 |
| batch mode in gimp, add alpha, change color | Kevin Cozens | 01 May 19:35 |
| batch mode in gimp, add alpha, change color | Xavier Mas | 01 May 21:00 |
| batch mode in gimp, add alpha, change color | Choi, JiHui | 02 May 01:05 |
| batch mode in gimp, add alpha, change color | David Gowers | 02 May 01:46 |
| batch mode in gimp, add alpha, change color | Marc T. | 27 Jul 16:30 |
| batch mode in gimp, add alpha, change color | David Hodson | 27 Jul 16:50 |
| batch mode in gimp, add alpha, change color | Marc T. | 27 Jul 17:10 |
| batch mode in gimp, add alpha, change color | Jay Smith | 27 Jul 17:38 |
| batch mode in gimp, add alpha, change color | Ken Warner | 27 Jul 18:29 |
| batch mode in gimp, add alpha, change color | Joao S. O. Bueno | 02 May 02:16 |
| batch mode in gimp, add alpha, change color | David Gowers | 02 May 03:24 |
Hi, all
I want to do some doing on my many images, about 1,000 ;;;;;
at first, add alpha channel at each image, and change color #fff to transparent.
I think, "open -> add alpha -> select #fff by color -> del -> save"
but I don't know script-fu. and tried some ways, all fail. please help me.
Greetings.
Choi, JiHui wrote:
I want to do some doing on my many images, about 1,000 ;;;;; at first, add alpha channel at each image, and change color #fff to transparent.
I think you would be better off doing this using ImageMagick and a shell script. The 'convert' program with the -alpha and -background options should allow you to do what you want.
El Thursday 01 May 2008 19:35:56 Kevin Cozens va escriure:
Or you can do an script using Scheme. GIMP allows to use any of its functions by script.
I know about ImageMagick, but there is no version for windows. even though I use windows and linux both.
I tried to learn scheme, but it's so difficult. and if I want another actions, I have to learn about relative functions. so I think, I just want to use gimp, not to learn scheme. I don't know and don't have any interesting about scheme.
humm.. anyway.. to learn scheme is the only way? Isn't there something better than DBP plugin?
On Fri, May 2, 2008 at 8:35 AM, Choi, JiHui wrote:
On Fri, May 2, 2008 at 2:35 AM, Kevin Cozens wrote: > I think you would be better off doing this using ImageMagick and a shell > script. The 'convert' program with the -alpha and -background options should > allow you to do what you want.
Not true.
see
http://www.imagemagick.org/script/binary-releases.php
"You can install ImageMagick from source. However, if don't have a
proper development environment or if you're anxious to get started,
download a ready-to-run Unix or Windows executable."
On Fri, May 2, 2008 at 4:00 AM, Xavier Mas wrote: > Or you can do an script using Scheme. GIMP allows to use any of its functions > by script.
Learning python would be easier.
http://www.gimp.org/docs/python/pygimp.html
I like to use the GIMP Python Console for batch processing. Here is an example, that processes all PNG files in the current directory.
import glob.glob
for filename in glob.glob ('*.png'):
image = pdb.gimp_file_load (filename, filename)
# put your batch processing commands here.
# for example
# pdb.gimp_threshold (image.layers[-1], 128,255)
# would threshold the bottom layer.
pdb.gimp_file_save (image, image.active_layer, filename, filename)
del image
Indeed!
No. Scehme is nto the only way. Nowadays you can do your script using python - which is a much better language in several terms.
You still use the PDB for some (even most) actions, but calling then from python makes a mucheasier to read and write program.
For operating on all images in a given dir,just do:
import os
from gimpfu import *
def do_it (givendir):
for filename in os.listdir(givendir):
pdb.gimp_file_open(filename, filename)
layer = image.layers[0]
layer.add_alpha()
pdb.gimp_by_color_select(drw, "#fff", 0, CHANNEL_OP_REPLACE, True, 0,
0, False)
pdb.gimp_edit_cut(layer)
pdb.gimp_file_save(image, filename, filename)
pdb.gimp_image_delete(image)
Followed by the "register" and "main" boilerplate code you can copy from any other python plug-in (there are a couple bundled with gimp-python install) - the "givendir" variable will be automatically inputed from a generated interface - you can use PF_DIR or PF_STRING for inputing it. (or even hard code it if you are running this only once)
For running gimp-python in windows, you need to install the Python language (from www.python.org), python-cairo and python-gtk+ bidings (I think just these).
js
http://www.gimptalk.com/forum/topic/Python-And-Gimp-2-4-25587-1.html
links to a single combined package, with step-by-step instructions,
available here:
http://photocomix-resources.deviantart.com/art/Gimp-Python-support-easier-74889017
i am on a similar problem,
i have to build a batch script that slices over 6000 images very big images
into seven pieces.
shell
ImageMagick seems to first read all images into memory and then working with
it.
and this dosn't work with some couple of GB and besides there is no status of
completness, so you never know when it'll be finished.
i wrote a batch FOR loop, but it turned out to be too slow, scince it has to
start image magick over and over...
i tried script-fu,
but scheme is just a little too wierd for me comming from a java,
background,
and there seems to be no error status messages,
for dubugging,
so i never know what i did wrong this time.
well
so
Gimp and Python seems to be good alternative,
but i have to start the script from commandline,
so how would you do this?
and i tried to copy this script to the python-fu console:
import glob.glob for filename in glob.glob ('*.png'): image = pdb.gimp_file_load (filename, filename) # put your batch processing commands here. # for example
# pdb.gimp_threshold (image.layers[-1], 128,255) # would threshold the bottom layer. #
pdb.gimp_file_save (image, image.active_layer, filename, filename) del image
it says it's missing the glob.glob, where would i get this?
thanx
marc
i have to build a batch script that slices over 6000 images very big images into seven pieces.
David's Batch Processor should be able to do the job, not by slicing but by cropping each slice out of the image one at a time. Not the most efficient technique, but it should work.
-- David
images
into seven pieces.
-- David
thanx for the quick reply,
but i really need to start the process from command line, to integrate it
into a bigger workflow.
and efficensy is a big isssue also,
otherwise i could just stick to imagemagick
i basically just need to know how i can start python batch scripts from
commandline,
can't find anything via google...
maybe it's too simple..
i have to build a batch script that slices over 6000 images very bigimages
into seven pieces.
-- David
but i really need to start the process from command line, to integrate it into a bigger workflow.
otherwise i could just stick to imagemagicki basically just need to know how i can start python batch scripts from commandline,
Mark,
I am speaking _without_ much experience here, and I am not the one who wrote the scripts, but we process thousands of images in large & small batches using ImageMagick. We use Perl, which has a ImageMagick module (or whatever you call it).
We have one Perl script that does the actual work. However, we use an outer wrapper Perl script to do the finding of the files that need to be worked on.
We run from the command line.
As far as I know, we are starting ImageMagick only once.
The process looks at about 40,000 potential source tiff images and makes sure that none are newer than the about 160,000 target jpeg images. If any tiffs are newer (or the jpegs don't exist), from each tiff, we make 4 jpegs of different output pixel dimensions, based on a complicated algorithm determining/scaling output pixel dimensions based on input image size (physical dimension as 300 dpi tiff).
If no images need to be made, then the whole thing runs in about 3 minutes or so.
(This is on a fairly old RedHat 8 linux server -- if it was running on my new workstation and if the files themselves were on my new workstation, it would at least double the speed.)
When images do need to be made, if the source tiffs are small (i.e. 300 KB), then they only take a couple seconds each. If the source tiffs are large (i.e. for us 10-20 MB), then they take maybe 6-10 seconds each depending upon what else is happening on the system. Again, these speeds could surely be at least doubled on better hardware.
Regarding your really big images > 1 GB, if you are working with stuff like than, then you need to be working with hardware that has enough memory. Images that large (perhaps these are satellite photos?) are surely "important", thus get a system that can do the job. Even my lowly workstation has 4 GB of RAM and two 1 TB hard disks and dual quad-core (2 GB I think?) processors. I think I spent $700 on it, not including the monitor. The hardware cost is NOT the problem. The problem is the skilled time to configure this kind of stuff to _really_ work.
Look at Perl with ImageMagick.
Jay
I'm a Java programmer also. Batch processing in GIMP using Scheme is just not a practical solution.
i tried script-fu,
but scheme is just a little too wierd for me comming from a java, background,
and there seems to be no error status messages, for dubugging,
