Tutorial: Create futuristic looking tech pattern
Written by , translated by redforce · Created on Feb 22, 2008, last updated over 14 years ago CC BY-NC License
This is one of these simple to do tutorials, but the effect just looks cool and pretty futuristic. So I've written a tutorial for it. Enjoy!
    Create a new image: 640×480 px. The Background should be plain white. Now choose Filters / Render / Clouds / Plasma.
    Take these values: 10.000 / tubulence: 7
    Go to Colors / Desaturate: Brightness and choose OK.
    Now we’re giving our pattern the special look which it will have at the end. We’re using the Dilate filter, a very simple filter that smallens the dark areas in an image. Don’t be confused if you look at the quick description when hovering the entry in the filter menu – I think currently in Gimp 2.4.4. this is a wrong description.
    Choose Filter / General / Dilate.
    After this repat that filter 30 times. Use CTRL+F to repeat the filter quickly.
    Got to Filter / Map / Make seamless.
    Sharpen the picture now using Filter / Enhance / Sharpen: ~85.
    Now we’re giving our picture some color: Use Colors / Color Balance
    Shadows: -50 | 30 | 30
    Mids: 0 | 30 | 50
    Highlights: -65 | -40 | 20
    If you zoom into the image very closely you’ll notice some gradients that are not very nice looking.
    To get rid of this we use Filter / Blur / Selective Gaussian Blur.
    Values: 5 / Max Delta: 13
    Now we want to have some cool glowing edges so that everything look really future style like.
    Zoom back to 100% (do this fast by clicking the “1”-key).
    Click “duplicate layer” in the layers dialog or just use the hotkey: CTRL+SHIFT+D
    On the duplicate use Filter / BLur / Gaussian Blur: 10.
    Set the layers mode (directly above the opacity ruler in the layers dialog) to “Lighten only”.
    Thats all, we are finished! The softer result is in the left part of the picture below.
    Option 1: If you want your edges to be sharper and more clearly looking use Filter / Enhance / Sharpen (40/50) again on the background-layer.
    Option 2: If you want the whole picture a bit darker (less white glow and more saturated colors) simply create a new totally black layer above all layers and set the layers mode to “Overlay”.
    Have fun with this ;) Hope you enjoyed this easy tutorial.
This topic (Create futuristic looking tech pattern) has been rated 5.0/5.0.
Edusoares
over 12 years ago
Thanks from Brazil.
Obrigado do Brasil.
Zaldusk rated this topic with 5/5
almost 15 years ago
Awesome, I love it! Thank you!
gimp user
over 15 years ago
coool thanxs
Dark Angel
almost 16 years ago
Thank you very much;
Wonderful work.
7rev
about 16 years ago
Thank you very much! it was very easy to follow and simple to make! :)
I added in a few things, but here is the attempt i made - http://forums.jokerice.co.uk/showthread.php?p=20333#post20333
and once again, thank you very much!
falloutboy
over 16 years ago
I actually did it! As what the others posted above me: It's simple yet awesomely looking! :D
myname
over 16 years ago
Didn't see the gradients on step 6, so step 7 wasn't needed. Using GIMP 2.6.1
zissan
over 16 years ago
thanks
looks like a magic.
Anonymous
over 16 years ago
Wonderful! I did whaqt you said as extras, both together and separately. I also messed with the colors. It looks great! Awesome!
Zavael
about 17 years ago
perfect and great :) thanks man
Robert
about 17 years ago
Yes very nice tech looking pattern! Thanks
Gimper member for about 17 years Gimper 1 comment
about 17 years ago
nice work devv, might come in handy
thanks
Pixkid member for over 17 years Pixkid 4 comments
about 17 years ago
Wow... really simple yet really awesome! Thanks for sharing.
