Fwd: XCode syntax highlighting plug-in for Script-fu
Fwd: XCode syntax highlighting plug-in for Script-fu Chad Jones 30 Mar 05:09
Chad Jones
2008-03-30 05:09:03 UTC (about 17 years ago)
Hi Everyone,
The XCode script-fu Scheme syntax highlighting plug-in can now also be found on the Wilber-loves-Apple website at:
http://darwingimp.sourceforge.net/download.html
You will need to scroll down to the bottom of the page to get it. Chad. :D
Chad Jones wrote: Date: Sat, 29 Mar 2008 11:12:13 -0700 (PDT) From: Chad Jones
Subject: XCode syntax highlighting plug-in for Script-fu To: gimp-user@lists.XCF.Berkeley.EDU
I'm not sure how many people use Mac OS X for Gimp Script-fu development. However, I have created and posted for XCode a free syntax highlighting plug-in for Script-fu. The plug-in will allow XCode to syntax highlight correctly any Script-fu code you use inside XCode. XCode normally comes bundled with Mac OS X as an optional install.
After installing XCode must be restarted and any XCode projects you intend to use may need to be recreated to get the syntax highlighting to take effect. Note this plug-in only provides syntax highlighting capabilities within XCode and doesn't allow XCode to compile, interpret or otherwise run Script-fu code.
You might need to register or signup with the yahoo script-fu group to get access to the files. Note to access the XCode syntax highlighting capabilities for Script-fu Scheme you will need to use the ".scm" extension on your script-fu files.
Enjoy. :)
Chad.
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
