How to separate layers
How to separate layers edward storm 09 Mar 21:19
  How to separate layers vt 09 Mar 21:59
   How to separate layers David Gowers 09 Mar 23:25
    How to separate layers Burnie at Tahoe 10 Mar 02:14
edward storm
2008-03-09 21:19:33 UTC (about 17 years ago)
My first Gimp project - make a menu with four different layers, one text, one colored page, a fuzzy border and a clear background. I printed it and loved it. Then I saved it as an XCF file. Now when I open it in The Gimp, it only has one layer. Can I get the original four back, and if so, how? (I'd like to add more text with a different font, etc.)
Thanks
vt
2008-03-09 21:59:24 UTC (about 17 years ago)
On Sunday 09 March 2008 22:19:33 edward storm raš?:
Thanks
You should first save as XCF and then print. And now I'm afraid, you'll have to do it again from a scratch. Practice makes perfect;)
David Gowers
2008-03-09 23:25:18 UTC (about 17 years ago)
> layers, one text, one colored page, a fuzzy border and > a clear background. I printed it and loved it. Then I saved it > as an XCF file. Now when I open it in The Gimp, it only has > one layer. Can I get the original four back, and if so, how? > (I'd like to add more text with a different font, etc.) >
> Thanks
You mean that the print plugin flattens the original image? Is there a bug filed for that?
Burnie at Tahoe
2008-03-10 02:14:40 UTC (about 17 years ago)
> Thanks
In my Linux system, the multiple layers remain on save after printing. What OS are you using?
