Tutorial: Create a simple waved stripe
Written by · Created on Mar 25, 2009, last updated over 14 years ago CC BY-NC License
This is a simple tutorial showing you how to make a nice waved stripe in GIMP that can be used for lots of different thinks such as forum sigs, wallpapers, website-header etc.
    Good, before you start with this tutorial, notice that I’m from Belgium, and I use the GIMP in Dutch, so I’ll have to translate some things, hope it’ll be clear. Open GIMP and create a new image. The width and height need to be the same, here I’ll use 1920×1920 (pixels).
    Go to filters – render – fractal explorer, then go to “fractals” and choose “Saturn”, press ok. Then go to colors – desaturate – second option
    Make a new, transparent layer and fill it in with a colour, here I use #009cfd (blue) but you can choose whatever colour you like, red, green, orange… Then go to layer mode and choose overlay. Click CTRL+M (or use Image / Merge Image) to merge the image into one remaining layer.
    Then use free selection tool (3rd selection from left) and cut the middle lines out (see screenshot if you don’t understand). Or cut the two big ones out of your picture.
    Now use the “Color picker tool”. Well, just use it and fill, select left side color first and fill the white with the “bucket fill tool”. The rest of the image should be filled with the right colour. (Notice that the colours on the right and the left side aren’t the same)
    You’ll see you have some white borders, fill them in with the right colour and you’re done!
bananenschale
almost 15 years ago
good tut! i decorated my stripe with the sparks-brush afterwards on a new layer and set it to soft light, loks really good
Faus member for about 16 years Faus 1 comment
almost 16 years ago
http://fc02.deviantart.com/fs43/f/2009/072/b/4/Long_lightning_by_Trash_lyric.png
Here you can find a waved stripe 1920x1920 px, you're free to download it and use it wherever you want
neil
almost 16 years ago
I think this tutorial is really helpful for me to make a nice waved stripe in GIMP. Thanks for the steps given in to the article that would be help me to understand easily. Keep writing like that.
http://www.Webdesignquote.ca
neil
almost 16 years ago
Web Design Quote
nalin
almost 16 years ago
nice
JPEGJedi member for over 17 years JPEGJedi 3 comments
about 16 years ago
That would be nice to have a script for it
Snowey
about 16 years ago
This can easely be converted to script-fu i presume. No reall human interaction needed :)
pikkermaker member for about 16 years pikkermaker 1 comment
about 16 years ago
ive got a tut but dont know how to write one.
Anyway, nice tut Faus, cool, thnx.
about 16 years ago
easy and cool ;) thanks for the tutorial!
