help
3 of 4 messages available
mailman.3.1203969603.19543.... 07 Oct 20:19
  help Mokla Com 25 Feb 21:58
   help Geoffrey 25 Feb 22:16
    help Patrick Shanahan 25 Feb 23:37
Mokla Com
2008-02-25 21:58:58 UTC (about 17 years ago)
help
pls unscribe me. thank you.
gimp-user-request@lists.XCF.Berkeley.EDU wrote: Send Gimp-user mailing list submissions to gimp-user@lists.XCF.Berkeley.EDU
To subscribe or unsubscribe via the World Wide Web, visit https://lists.XCF.Berkeley.EDU/mailman/listinfo/gimp-user or, via email, send a message with subject or body 'help' to gimp-user-request@lists.XCF.Berkeley.EDU
You can reach the person managing the list at gimp-user-owner@lists.XCF.Berkeley.EDU
When replying, please edit your Subject line so it is more specific than "Re: Contents of Gimp-user digest..."
Today's Topics:
1. Re: . Re: Deconvolution plugin for GIMP? (Doug) (Toby Haynes) 2. Re: . Re: Deconvolution plugin for GIMP? (Doug) (Doug) 3. Re: ? about shrinking pics on GIMP 2.... (Matthias Julius)
Message: 1 Date: Sun, 24 Feb 2008 20:28:23 -0500 From: Toby Haynes
Subject: Re: [Gimp-user] . Re: Deconvolution plugin for GIMP? (Doug) To: gimp-user@lists.XCF.Berkeley.EDU Message-ID:
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Alchemie foto\grafiche wrote:
'd be interested to know of any such plugin too. I have a number of images with directional camera shake that Refocus fails to handle at all well.
did you try convolution matrix ( in Filter/Generic)
That applies the convolution to the image. In this case I want to reverse the process - which is a lot harder to do and has been the subject of many papers. Of all the approaches I've seen, I've been most impressed with the Maximum Entropy approaches to deconvolution - however, those require a reasonable guess at the original convolution function (prior).
Cheers,
Toby Haynes
Message: 2 Date: Mon, 25 Feb 2008 09:53:16 +0000 From: Doug
Cheers,
Toby Haynes
______________________________________________
That would be completely beyond me, unfortunately! Cheers,
Doug
Message: 3 Date: Mon, 25 Feb 2008 14:35:23 -0500 From: Matthias Julius
Subject: Re: [Gimp-user] ? about shrinking pics on GIMP 2.... To: gimp-user@lists.xcf.berkeley.edu Message-ID:
Content-Type: text/plain; charset=us-ascii
Rei Shinozuka writes:
shrinking images always involves some form of smoothing, and some amount of sharpening afterwards is generally useful. i usually do this:
Shrinking of screenshots is generally problematic as there are probably many features on there that are only 1 pixel wide (lines and text). If you scale that down it is doomed to look ugly.
A 1 pixel wide black line on white background will end up gray if scaled down. Sharpening can improve that.
A small font where every pixel counts will be unreadable and no sharpening can recover that.
What are the images for?
Matthias
Geoffrey
2008-02-25 22:16:16 UTC (about 17 years ago)
help
Generally, when you find yourself somewhere you don't want to go, you can leave the way you came. See the link below which comes with all posts to the list:
Patrick Shanahan
2008-02-25 23:37:19 UTC (about 17 years ago)
help
* Geoffrey [02-25-08 16:25]:
how is he going to see it? He obviously doesn't *read* the list!
