Curves Preview on first click
Curves Preview on first click Rich 21 Feb 05:51
  Curves Preview on first click Sven Neumann 21 Feb 08:26
   Curves Preview on first click Rich 22 Feb 06:17
  Curves Preview on first click Leonard Evens 21 Feb 17:24
Rich
2008-02-21 05:51:26 UTC (about 17 years ago)
Can you verify if you get the same results when you do the following:
- click curves under colors menu - dialog appears, channel value, logarithmic mode, preview enabled, and curve type smooth
click once anywhere above or below the line in the graph display, the line will add a point, and snap the line to the point, but nothing occurs in the image preview.
If you click a second time, a second point is added and the preview updates Click reset
Now drag the line for the first point, preview works fine.
I tried in linear, same results. Freehand displays preview correctly.
Should only the dragging method be used. Thanks.
Rich
2008-02-21 08:26:46 UTC (about 17 years ago)
Yes, I can reproduce this problem with GIMP 2.4. It would be nice if you could file a bug report for this at bugzilla.gnome.org so that we don't forget about it. Thanks.
Leonard Evens
2008-02-21 17:24:31 UTC (about 17 years ago)
I noticed the same thing, but if I move the cursor slightly after clicking, the display does change.
Rich
Rich
2008-02-22 06:17:14 UTC (about 17 years ago)
Thanks.
I submitted a bug report.
Rich
