Documenting Gimp Color Management
10 of 11 messages available
Documenting Gimp Color Management Leonard Evens 05 Feb 20:43
  Documenting Gimp Color Management Sven Neumann 05 Feb 21:25
   Documenting Gimp Color Management Leonard Evens 06 Feb 00:51
    Documenting Gimp Color Management julien 06 Feb 06:58
     Documenting Gimp Color Management Sven Neumann 06 Feb 08:18
      Documenting Gimp Color Management Axel Wernicke 09 Feb 03:06
       Documenting Gimp Color Management Leonard Evens 09 Feb 17:58
        Documenting Gimp Color Management Axel Wernicke 10 Feb 00:11
         Documenting Gimp Color Management Leonard Evens 10 Feb 00:31
1202528873.3144.605.camel@a... 07 Oct 20:19
  Documenting Gimp Color Management Axel Wernicke 09 Feb 08:58
Leonard Evens
2008-02-05 20:43:37 UTC (almost 18 years ago)
I am contemplating writing a tutorial on gimp color management. I'm not sure I know enough yet to do it, but I suppose someone has to begin.
It would help me a lot if I could actually examine the code to see what gimp is doing. Otherwise I have to keep running experiments, and aside from being time consuming, it sometimes gives misleading or inconsistent results, particularly since my understanding of color management detail still has some gaps. At various times in the past, I've tried to delve into gimp code to see what it does, but it is not an easy task for someone who may be familiar with C but has not worked with the complex development tree.
Anything along those lines that would help would be appreciated.
2008-02-05 21:25:31 UTC (almost 18 years ago)
I am sure the gimp-docs team would love to get a chapter on color management for the user manual. Perhaps you want to coordinate your effort with them.
Leonard Evens
2008-02-06 00:51:56 UTC (almost 18 years ago)
I would be happy to do that, but I don't know how. I checked the Gimp documentation Developer's web page, and figuring out how to join in looks like an imposing task. I understand why that is necessary for such a project, but at my age I'm not sure I'm ready to master a whole new framework and set of skills, e.g., using XML. It was hard enough mastering the basics of color management and how to use profiling tools, and I still haven't figured out all of that.
I think I will prepare a simple tutorial, explaining what I know and let anyone make any use of it that they may.
julien
2008-02-06 06:58:51 UTC (over 17 years ago)
Help on how using profiling tools is very welcome. You can write a normal text and send it me: I'll transform it to XML.
Julien
2008-02-06 08:18:15 UTC (over 17 years ago)
That will be very much welcomed.
Since GIMP doesn't include any profiling tools, it would be out of scope of the user manual to explain how to use them. A decent documentation on the color management features in 2.4 is what is really needed at this point.
Axel Wernicke
2008-02-09 03:06:21 UTC (over 17 years ago)
I just wanted to let you know that there is already "something" about the new color management features in the documentation. Feel free to read this
- - http://docs.gimp.org/en/gimp-imaging-color-management.html - - http://docs.gimp.org/en/gimp-pimping.html#gimp-prefs-color-management - - http://docs.gimp.org/en/glossary.html#glossary-rendering-intent - - http://docs.gimp.org/en/gimp-imaging-color-management.html
and please, don't hesitate to correct what's written or fill the gaps. Everything in there is to my best knowledge but I'm sure it is neither completely correct nor are all necessary topics in there yet.
Greetings, lexA
P.S: as Julien already mentioned - if you feel not comfortable writing docbook xml, just give us plain text to incorporate.
- -- Remember: There are only two tools in life. WD-40, for when something doesn't move, and should, and Duct Tape, for when something is moving and it shouldn't.
So does the universe explode if you spray duct tape with WD-40?
-----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.8 (Darwin)
iD8DBQFHrQqeR9mXLVsAbiQRAntfAJ9FdQqHCMANjDzybGlMrY0tCMq9FACgsXAx AW7MEb5dkf7chKksvIUTc5o=
=zTgP
-----END PGP SIGNATURE-----
Axel Wernicke
2008-02-09 08:58:16 UTC (over 17 years ago)
Am 09.02.2008 um 04:47 schrieb Leonard Evens:
I haven't yet had a chance to thoroughly examine what you've done, but I
plan to soon, and I will come up with additional comments.
That is what I'm hoping for
Let me start by bringing up one issue, which it took me a long time to get straight, and which at first glance I didn't find in what you did. I'll describe it below as best I can. I don't know how or where to incorporate it in the documentation, particularly since some of it seems
to be operating system dependent. I do think it is important so I hope
you will fit it in, perhaps in an easier to understand simplified form.
I'll try read, understand and include that into the docs.
In this connection, let me say that I think it is a mistake to prepare the documentation as if Linux users were odd balls who should be using XP or MacOS.
Whops! - Did we do this? I think most members of the documentation team are even working on Linux. The manual should of course not discriminate any operating system or their user base. Please let the documentation team know about such in detail by telling us and giving a reference to the page in question (as http://docs.gimp.org/en/...)
Greetings, lexA
- --- Live is like a chocolate box, you never know what you wanna get... GPG Signatur auf http://wernicke-online.net/Impressum/ prüfen
iD8DBQFHrV0ZR9mXLVsAbiQRAvKBAKDTvIES8OWxn1Yn34lV18rAx/O01gCgz66L jkn2SHt2PFhCS2/K/8FmnYI=
=rD95
Leonard Evens
2008-02-09 17:58:54 UTC (over 17 years ago)
Greetings, lexA
I am attaching a second installment of comments as a text file below. I'm afraid the comments come across just as criticisms, so let me emphasize how much I appreciate what you've already done. Ideally, rather than just complaining about this or that, I should suggest how I would phrase it instead. Unfortunately, I don't feel comfortable about writing documentation of this kind yet, so I would rather just raise points and hope you can figure out what I'm saying and include it in the documentation if it seems appropriate. I'm sure you will do a better job of it than I would at this stage. When I feel more comfortable, I will suggest appropriate wording.
Also, remember that there are several color management issues and, more important, issues about exactly what gimp does that I find mysterious. So some of my comments might just indicate ignorance or misunderstanding. Even so, I am a relatively experienced gimp user who is Linux savvy and knows something about color management. So if I am confused by something, there is good chance that an average user will also be confused.
I would find it easier to understand what gimp is actually doing if I could get at its guts. Instead, I have to do experiments and the results can sometimes be misleading. I've tried several times to look at code, but I've been defeated each time, not by the code, but by the complex structure of the source tree. Any suggestions about how to learn about that without making it my life's work would be appreciated.
=zTgP
Axel Wernicke
2008-02-10 00:11:23 UTC (over 17 years ago)
Hi Leonard,
Am 09.02.2008 um 17:58 schrieb Leonard Evens:
Since I explicitly asked for it, I should (and do) stand that now ;) By now I did not fully examine what you wrote, but I'll do so in the next couple of days.
Well, let it put me this way: your english can't be worse than mine. Unfortunately there are right now 0 (in words: zero) native speaking people in the documentation team - the only reason for me writing english content is that there is no alternative :(
I most probably can't answer them too. If in doubt we need to ask the devs.
Greetings, lexA
- --- Remember: There are only two tools in life. WD-40, for when something doesn't move, and should, and Duct Tape, for when something is moving and it shouldn't.
iD8DBQFHrjMcR9mXLVsAbiQRAlj2AJ0WqEC/8XM81gW5SMs4GZaMjpN+zACg9WZF JztRPAqgxQNeHWt7xVA1H1Y=
=1fXZ
Leonard Evens
2008-02-10 00:31:18 UTC (over 17 years ago)
Hi Leonard,
Your English is fine. My concerns about my writing documentation are more basic than that. I'm worried that were I to write documentation, I might make it so complicated it would be useless. It is question of deciding how to put things so people can understand it easily but aren't led astray by having things be oversimplified. But give me some time. I've lots of experience explaining complex matters to generations of mathematics students, and some of that may carry over.
I would be happy to be the resident native speaker of English. I haven't seen any problems of that nature yet, but should I find any, I will be happy to correct them.
Greetings, lexA
=1fXZ
