paint with patterns
paint with patterns Helen 18 Jan 16:02
  paint with patterns Elwin Estle 18 Jan 16:58
   paint with patterns Joao S. O. Bueno 18 Jan 18:30
Helen
2008-01-18 16:02:48 UTC (over 17 years ago)
paint with patterns
Is it possible to use the airbrush (or any paint tools) to paint with the patterns?
Thanks,
Helen
Elwin Estle
2008-01-18 16:58:31 UTC (over 17 years ago)
paint with patterns
Not with the paint tool, but you can set the clone tool to use a pattern source.
Thanks,
Helen
Joao S. O. Bueno
2008-01-18 18:30:35 UTC (over 17 years ago)
paint with patterns
Thanks,
Helen
Furthermore, if you want specifically the airbrush, you can do that with layer masks.
Fill a layer above the one you want to paint with your pattern, create a layer mask for it, and select Black (all trasnparent). Then use paint on this mask with white, using wahtever tool you want.
js ->
using Linux, SuSE 10
