Some questions about script-fu and tinyscheme.
Some questions about script-fu and tinyscheme. Pere Pujal i Carabantes 22 Aug 01:43
  Some questions about script-fu and tinyscheme. Pere Pujal i Carabantes 22 Aug 22:36
  Some questions about script-fu and tinyscheme. Pere Pujal i Carabantes 23 Aug 19:30
2007-08-22 01:43:38 UTC (over 17 years ago)
Hi!
The first is about writing text to a file. In SIOD doing something like this I can write text to a file:
(let* ( (txt-output-file-name (string-append base-filename ".txt")) (txt-output-file (fopen txt-output-file-name "w"))) (fwrite (string-append text-string "\n")txt-output-file) (fclose txt-output-file))
If I try the same in tinyscheme it raises an error. How can I do the same in tinyscheme?
For now, I've worked around as this, but looks ugly:
(begin (define text-filename (string-append base-filename ".txt")) (define txt-output-file (open-output-file text-filename)) (for-each (lambda (z)(write-char z txt-output-file ))(string->list text-string))
(newline txt-output-file))
The second question is about the memory used by gimp-image-undo-group start->end.
If I use this, my script easy eats all the memory. (It creates, moves and destroys 49 layers per an undetermined number of runs)
I've created a simple script to test and show: http://fornol.no-ip.org/linux/gimp/group-undo-test.scm Defaults to create and destroy 20 layers x 5 runs = 100 layers and group-undo each run.
Create a new blank image (420x300 pixels) run the script on it script-fu-->test-->group-undo If you check group-undo you will get an image about 193MB If you don't check, the image will use 64.2MB
Well, I have setted 64MB as max undo memory, but why this set is not used when grouping undo?
Thanks Pere
2007-08-22 22:36:21 UTC (over 17 years ago)
Solved this, that was a misconfiguration on my hand. I had setted a minumun undo levels of 5 an this take precedence over the max memory for undo.
Pere
2007-08-23 19:30:24 UTC (over 17 years ago)
better as this:
(display text-string txt-output-file)
BTW The gimp script-fu console segfaults typing something like (let* (a 1))
Should I post a bug report?
gimp 2.4.0-rc1
Yours Pere
