Tutorial: Generate a cool tech pattern
Written by · Created on Jul 07, 2007, last updated almost 15 years ago CC BY-NC License
Someone often needs a cool pattern that can be used for a forum signature, a banner, a wallpaper or something else. This simple technique shows you how to make such "tech" pattern.
    File / New: 500×300px. You can just work on the background layer. The color is irrelevant for this. Filter / Render / Coulds / Plasma. Choose any values.
    Filter / Blur / Pixelize: X:10 | Y:10
    Filter / Map / Bumpmap and enter the values of image below:
    You should get something like this:
    Next apply: Filter / Edge-Detect / Edges:
    Algorithm.:Roberts
    Amount: 2
    Wrap
    You can of course apply Colors / Brightness & Contrast to get some personal fine tuning. And also consider Filter / Enhance / Sharpen which looks cool too if you sharpen the image a bit.
    Below you see 3 different versions of this and how it could look like!
Heruman
over 13 years ago
easy steps with fast results .. thanks a lot bro
Fantasia
over 14 years ago
Thanks for the great tutorial! The end result looks nice and has many applications.
Kyra10987
about 16 years ago
The Edge Detect screwed mine up, so I used Filters< Laplace
ryan
almost 17 years ago
Nice and quick. thanks!
halozmatt member for about 18 years halozmatt 7 comments
over 17 years ago
May i ask to put this on GimpDome?
LordEimer
over 17 years ago
6 weeks is a while btw if yu don't write down what you do^^
LordEimer
over 17 years ago
It's been a while since I created this one, so I don't remember every step. But if you follow this, you should create something like it.
1) create a b/w Text layer (b text)(ca 1000x500)
2) create a clouds layer, set blend mode to lighten
3)merge layers
4)pixelize ( ca 12,text should still be readable)
5) blur ( 3px)
6)detect edges (roberts)
7)rescale image ( 2000x1000)
8) duplicate layer
9)set top layer blend mode to screen
10)pixelize 5 px (top layer)
11)blur 1 px (top )
12) detect edges (sobel)(top) layer
13) merge layers, add colors and scale down again
i hope this helps, perhaps you can figure out on your own how to improve it.
Lord Eimer
Ozzy8
over 17 years ago
LordEimer: OH GOD! how to do that? :)
LordEimer
over 17 years ago
also works great as a text effect
over 17 years ago
that looks pretty cool, i really like it ;)) thanks for posting this
LordEimer
over 17 years ago
if you pixelize the result again with
a smaller pixel-size, blur again, detect egdges again and overlay this with the first result you can get something like this
about 18 years ago
eh...thank you very much, i'm actually EXTREMELY new to 'the gimp' but eh, in 3 days just searching on gimpusers and gimp-tutorials, etc...gives you so much knowledge that it's actually educational, and the reason i've been doing it so much is because, lately...my internet has like been relly slow so i can't play halo lol...anyways thanks, friends ^.^?
about 18 years ago
nice combination of thiose two tutorials ;)
about 18 years ago
teh ownage i made one for a friend with same as mine, but then i undid it all and did the inverse of color balances ^_^
about 18 years ago
that's awesome....
about 18 years ago
that's pretty cool.
here's my results hehe.
Nazomie
over 18 years ago
great job love this tutorial, it really helps ^_^ thnx
weirdpeople member for over 18 years weirdpeople 1 comment
over 18 years ago
nice thats a great tutorial and easy too :-)
