pattern tool help
pattern tool help Jon Winters 16 May 07:45
pattern tool help Henry Meyerding 16 May 14:28
Jon Winters
2002-05-16 07:45:30 UTC (almost 23 years ago)
pattern tool help
Henry Meyerding wrote:
I have been trying to figure out the pattern tool, but cannot get it to work. Can anyone provide me with a simple, repeatable procedure that I can attempt that will allow me to see how patterns is supposed to work?
Select a pattern in your tool box or from the pattern palette.
Double click on the "bucket fill" tool and adjust its properties to "pattern fill" (FG Color Fill is the default)
Now just click on the area of your image you want to fill with the pattern and it should fill.
Adjust the threshold for more or less coverage.
Enjoy!
Henry Meyerding
2002-05-16 14:28:45 UTC (almost 23 years ago)
pattern tool help
Thanks
Henry W. Meyerding
