Making a Stereoimage of Each Layer
Making a Stereoimage of Each Layer spammy 02 Aug 22:05
  Making a Stereoimage of Each Layer Chris Mohler 02 Aug 22:29
  Making a Stereoimage of Each Layer Sven Neumann 02 Aug 22:36
   Making a Stereoimage of Each Layer Bob Meetin 02 Aug 23:41
spammy
2007-08-02 22:05:01 UTC (over 17 years ago)
I recently found myself needing to append a copy of an image right next to itself, essentially doubling the width of the canvas and ending up with a "stereoimage" more or less. Unfortunately, the image consisted of many layers, and I had to copy-n-paste the content of each layer and then move it to the side, layer by layer. Well, at least I "had to" in the sense that I didn't know any better.
I foresee myself having to do the same again, and was wondering if there was some fancy way to copy/paste/move all the layers at the same time, or if there might be an even better approach to this.
Thanks!
-Chris
Chris Mohler
2007-08-02 22:29:25 UTC (over 17 years ago)
One way: duplicate each layer (button at the bottom of the layers palette), link all of the copies (toggle to the right of the "eyeball" next to each layer), then drag them over to the side.
There might be an easier way...
Chris
2007-08-02 22:36:14 UTC (over 17 years ago)
Do you actually still need the individual layers? Otherwise you could simply flatten the image or merge visible layers before you create the stereo image.
You can link layers by toggling the chain icon in the layers dialog. Linked layers can be moved together.
Bob Meetin
2007-08-02 23:41:24 UTC (over 17 years ago)
If you are doing something like this repetitively you might want to consider using ImageMagick and its command-line tool, convert. It can be used to combine sequentially either horizontally or vertically multiple images. No more said as that is another user group. -Bob
