Problems with invoking GIMP from Mozilla
2 of 3 messages available
Problems with invoking GIMP from Mozilla Gustav Svensson 13 May 11:07
gurra16@spray.se 07 Oct 20:15
  Problems with invoking GIMP from Mozilla Jeff Trefftzs 13 May 17:57
Gustav Svensson
2002-05-13 11:07:41 UTC (almost 23 years ago)
I use the GIMP for viewing images opened with Mozilla. Look at the attached screenshot, which is from Mozilla configuration.
The thing is, if I include flags in the command line (e.g. -> gimp -d) the flags are not acknowledged by GIMP. How should I do?
Secondly, for each image that I open with Mozilla, a new GIMP session is opened, so that if I have 5 images up and running, there are also 5 GIMP toolboxes. How can I make all the opened images go into the very same toolbox?
Gustav _______
Jeff Trefftzs
2002-05-13 17:57:27 UTC (almost 23 years ago)
Hi Gustav -
I haven't tried this, so it may not work, but have you looked at gimp-remote? Maybe that's what you want to use with Mozilla instead of gimp -d. Check out man gimp-remote.
HTH,
