Newbie install problem
Newbie install problem Ralph Jones 11 May 05:24
  Newbie install problem Carol Spears 11 May 06:10
Ralph Jones
2002-05-11 05:24:00 UTC (almost 23 years ago)
I just upgraded my Redhat installation from 7.1 to 7.2, and the first time I started Gimp 1.2.1 it put out a long series of "Can't load" and "compilation aborted" messages. The GUI comes up OK, but it looks as if a lot of the plugins didn't load.
I then installed Gimp 1.2.3 via the config/make/make install route from /usr/local/src/gimp-1.2.3, and it produces the same result.
Suggestions? Thanks...
rj
Carol Spears
2002-05-11 06:10:26 UTC (almost 23 years ago)
first thing, get rid of anything gimp that occures underneath /usr. best way is to use the unistall rpm options, but even then, check for libgimp and for /usr/bin/gimptool. make might be finding these things.
once that is done, run ldconfig.
then rm config.cache.
then ./configure. watch the config spew. config complains if there is a problem or something unusual.
good luck. it is worth it. red hat has some screwed up gimp rpms.
On 2002-05-10 at 2124.00 -0600, Ralph Jones typed this mail:
rj
