WMF conversions
Hi Bret,
You did not specify your OS, but if you are using Windows convert your XCF
files to something else
(PNG for example) and download IrfanView from http:www.tucows.com .( IV is
not cheap; it is FREE.)
Cheers,
Denis McCauley
ORIGINAL MESSAGE
To: gimp user list
Date: 02 May 2002 11:50:31 -0500
Subject: [Gimp-user] any tools to convert raster to vector format?
I have som floorplans that I would like to import into AutoCadLite but
since they are simple scans of printouts I can't. AutoCad Lite only
recognizes autocad file typs and wmf files.
I have these grey scale scanned images in xcf format. Are there any
cheap tools that will read anything I can save as in gimp and then
convert them to wmf?
Bret
_______________________________
