problem saving as png
25 of 25 messages available
problem saving as png Anthony Ettinger 22 Jan 13:46
  problem saving as png Scott Bicknell 22 Jan 18:46
   problem saving as png Anthony Ettinger 22 Jan 20:38
    problem saving as png Anthony Ettinger 22 Jan 20:41
     problem saving as png Jeffrey Brent McBeth 22 Jan 20:48
      problem saving as png Anthony Ettinger 22 Jan 20:58
       problem saving as png Matthias Julius 22 Jan 22:14
        problem saving as png Anthony Ettinger 22 Jan 22:18
         problem saving as png Matthias Julius 23 Jan 00:18
          problem saving as png Anthony Ettinger 23 Jan 00:26
       problem saving as png Scott Bicknell 22 Jan 22:29
     problem saving as png Olivier Ripoll 23 Jan 10:30
      problem saving as png Anthony Ettinger 23 Jan 16:53
       problem saving as png Chris Mohler 24 Jan 00:33
    problem saving as png Jeffrey Brent McBeth 22 Jan 20:45
problem saving as png Michael Clark 23 Jan 21:08
  problem saving as png Jeffrey Brent McBeth 23 Jan 21:10
   problem saving as png Scott Bicknell 23 Jan 21:14
    problem saving as png Bill Lee 23 Jan 23:08
     problem saving as png A 24 Jan 02:28
      problem saving as png Patrick Shanahan 24 Jan 02:39
       problem saving as png Anthony Ettinger 24 Jan 02:47
        problem saving as png Joao S. O. Bueno Calligaris 24 Jan 03:28
         problem saving as png A 24 Jan 12:47
         problem saving as png Anthony Ettinger 24 Jan 23:48
Anthony Ettinger
2007-01-22 13:46:17 UTC (about 18 years ago)
I've been through this before, I usually just change the bg of the image to the one i'm using, but with #99cc00; as my body bg, I cannot for the life of me, save that same color.
Scott Bicknell
2007-01-22 18:46:17 UTC (about 18 years ago)
I'm trying to figure out what you are talking about. I created an image and filled it with the color you specified, then saved it as a png. No problem. I opened it in Gimp to see if there is some problem with that color in png's and Gimp. Again, no problem. Can you describe exactly what you are doing and point to an example?
Anthony Ettinger
2007-01-22 20:38:48 UTC (about 18 years ago)
Create an html page with background-color of #9c0; then do the same with the image in GIMP, and save as PNG.
I'm seeing color variation.
Anthony Ettinger
2007-01-22 20:41:30 UTC (about 18 years ago)
I made a test case:
http://chovy.dyndns.org/gimp/test/green.html
2007-01-22 20:45:58 UTC (about 18 years ago)
I've tried that exact experiment just now, and see no variation. Perhaps you are doing something more that makes it a problem?
http://broggs.org/~mcbeth/foo.html
2007-01-22 20:48:49 UTC (about 18 years ago)
On Mon, Jan 22, 2007 at 11:41:30AM -0800, Anthony Ettinger wrote:
I made a test case:
Looks like an IE6 bug. Firefox and Opera both show it as the same color.
Jeff
Anthony Ettinger
2007-01-22 20:58:53 UTC (about 18 years ago)
I made a test case:
Not on linux, FF is doing the same thing. Opera and Konq look ok.
Matthias Julius
2007-01-22 22:14:44 UTC (about 18 years ago)
"Anthony Ettinger" writes:
I made a test case:
Are you sure this is not some setting in FF sinc you made that image a link?
When you open that image in Gimp and compare that with that webpage, does it in Gimp look like background or the foreground of the webpage?
Matthias
Anthony Ettinger
2007-01-22 22:18:40 UTC (about 18 years ago)
I made a test case:
Matthias
The link doesn't have any effect on it. I added a link so I could show a border around it when hovered.
Scott Bicknell
2007-01-22 22:29:08 UTC (about 18 years ago)
I'm using FF 2.0 on SUSE 10.1 and see no difference in the color between the image and the background.
Matthias Julius
2007-01-23 00:18:17 UTC (about 18 years ago)
You can have this effect with any HTML element. You don't need a link for that.
Matthias
Anthony Ettinger
2007-01-23 00:26:40 UTC (about 18 years ago)
Matthias
That was for IE
Olivier Ripoll
2007-01-23 10:30:28 UTC (about 18 years ago)
I made a test case:
I see no problem at all on XP with FF2, Opera 9 or IE7, they all look fine on your page (i.e. same colour for image and backgoround). However, I remember I had a similar problem many years ago with a Macintosh. I think it was related to Gamma correction. Apples had (and probably still have) a different gamma setting, and this was creating a difference then (probably because my PNG did not contain the Gamma information then). Check that your PNG contains the Gamma information, and that your browsers can use it.
Best regards,
Olivier.
Anthony Ettinger
2007-01-23 16:53:37 UTC (about 18 years ago)
I made a test case:
Best regards,
Olivier.
Thanks, but I've done it every which way from hell and back, and still looks off in FF/linux.
Michael Clark
2007-01-23 21:08:16 UTC (about 18 years ago)
Anthony Ettinger
Ph: 408-656-2473
http://chovy.dyndns.org/resume.html
http://utuxia.com/consulting
Your test case webpage at
http://chovy.dyndns.org/gimp/test/green.htmllooks fine to me. I'm using a Mac and Firefox
2.0 here....
2007-01-23 21:10:29 UTC (about 18 years ago)
As he has repeatedly stated, the problem is under FF/Linux. There are many things in which FF/Win FF/Max and FF/Linux are different. It looks like FF/Linux isn't up to date with Gamma correction for some reason
Jeff
Scott Bicknell
2007-01-23 21:14:41 UTC (about 18 years ago)
Still, it seems to be specific to your setup. Mine, as I said in an earlier post, shows no color differences using FF 2.0 and SUSE 10.1.
Bill Lee
2007-01-23 23:08:16 UTC (about 18 years ago)
FF1.5.0.9 running under FC5: no visible difference.
Your problem is NOT a FF/Linux issue.
Bill Lee
Chris Mohler
2007-01-24 00:33:15 UTC (about 18 years ago)
Looked AOK to me this morning - the link doesn't seem to be coming up now.
I'm running FF 1.5.0.9 on Fedora 6.
Chris
A
2007-01-24 02:28:53 UTC (about 18 years ago)
Actually - since the file and web page itself is OK, for some (... some people can see it correctly) then using simple logic, the problem isn't to do with The GIMP ...
If there is something wrong with the file then no one should be able to see it correctly ... unless the display process is correcting the problem ... ... doesn't sound likely ...
and thus it most likely IS a FF or Linux issue.
i.e. the people not seeing it correctly must have
either: a) a setting "issue" in FF or Linux (display)
or: b) using a version of FF or Linux (display driver) with that "issue"
Bill Lee
Patrick Shanahan
2007-01-24 02:39:58 UTC (about 18 years ago)
* A [01-23-07 20:31]:
more likely, they have configured FF or their X display incorrectly, probably FF.
Anthony Ettinger
2007-01-24 02:47:00 UTC (about 18 years ago)
I'm suspecting my X server or questionable nVidia driver or my new monitor is responsible...anyway, it seems not a gimp issue, but I figured I'd ask anyway.
Just to make sure I'm saving the image correctly, this is my process:
1 layer: with text 1 background (alpha channel removed): color: #99cc00; When I save as .png, I check the "save gamma", UNcheck "save background-color", and check the last item: "dither transparency from background".
Can someone please confirm that these are the correct steps moving forward with transparent PNG?
2007-01-24 03:28:54 UTC (about 18 years ago)
1 layer: with text
hhmm?? if you want the text, without the surrounding background to show up over the green bg of the page, why not just save it witha trasnaprent background? Just turn off the visibility of the background layer before saving.
Actually, checking the " save gamma" optin is a good candidate for the color difference to show up at all!!! The problem is _all_ about gamma correction. You should e tried with9u tit already.
UNcheck "save
background-color",
NP. this doe snothing, but zero out tthe transparent area
Uncheck this - you don't want dithered transparency, you wnat true transparency!
js
A
2007-01-24 12:47:13 UTC (about 18 years ago)
1 layer: with text
Actually - making a transparent background (as probably most realise) means that IE6 will probably pick a color to place there ... which is probably the original reason for the question ...
and just an FYI - my successful display test was: FC5=2.6.18-1.2257 + FF1.5.0.8 + nv=6600GT
Anthony Ettinger
2007-01-24 23:48:35 UTC (about 18 years ago)
1 layer: with text
UNcheck "save
background-color",
This worked everywhere but IE6.
If i leave the bg color intact, it dithers inproperly in FF.
