Can Gimp start with something less dangerous than a brush
5 of 6 messages available
mailman.1.1166126403.22341.... 07 Oct 20:18
  Can Gimp start with something less dangerous than a brush George Farris 14 Dec 22:07
   Can Gimp start with something less dangerous than a brush Russbucket 15 Dec 03:24
    Can Gimp start with something less dangerous than a brush User1001 15 Dec 06:25
     Can Gimp start with something less dan gerous than a brush John R. Culleton 17 Dec 15:19
      Can Gimp start with something less dangerous than a brush Michael Schumacher 17 Dec 15:34
George Farris
2006-12-14 22:07:20 UTC (over 18 years ago)
On Thu, 2006-14-12 at 12:00 -0800, gimp-user-request@lists.XCF.Berkeley.EDU wrote:
Yes +1
Russbucket
2006-12-15 03:24:07 UTC (over 18 years ago)
Yes +1
I agree this one caught me a couple of times, maybe the select box.
User1001
2006-12-15 06:25:00 UTC (over 18 years ago)
Select the desired startup/initial tool, then save your Preferences, which also saves the currently selected tool - which then gets selected the next time Gimp2 is started:
0) Select desired tool to start up with 1) File/Preferences/Input Devices
2) Save Input Device Settings Now
3) OK
Yes +1
John R. Culleton
2006-12-17 15:19:32 UTC (over 18 years ago)
3) OK
Thanks for the useful routine, whch was more helpful than simply answering:
Yes +1
Now we need to convince the Powers That Be to make that the default out of the box. Also, the PostScript output routine defaults to vertical and horizontal offsets of 20 pixels each. These settings have no utility that I can see. I know how to patch this and recompile but it would save time if I didn't have to do this for each successive release.
2006-12-17 15:34:31 UTC (over 18 years ago)
Well, it had been this way - the rectangular selection was the default tool before 2.2, iirc. But many people did complain that GIMP does nothing on newly opened images, so it has been changed.
Why don't you open a report in Bugzilla and attach the patch?
HTH, Michael
