easier round corner tabs
easier round corner tabs Anthony Ettinger 07 Dec 23:19
  easier round corner tabs Chris Mohler 08 Dec 00:47
   easier round corner tabs Anthony Ettinger 08 Dec 00:51
    easier round corner tabs Chris Mohler 08 Dec 00:58
     easier round corner tabs Anthony Ettinger 08 Dec 03:40
Anthony Ettinger
2006-12-07 23:19:35 UTC (over 18 years ago)
I need an easier way to resize a tab background for use in css+xhtml without having to recreate each time I resize.
The problem is that if I need to resize the tab width, I have to re-do the entire tab creation. Is there a way to simply edit the selection after resizing? I've been doing the following:
1) three layers filled with: bg color, border color, fg color 2) create rounded selection (25% radius) 3) select border color layer, invert and clear 4) select fg color layer, shrink selection by 1, invert and clear 5) save as .png.
the problem is I have to redo all this if I resize the image.
Chris Mohler
2006-12-08 00:47:42 UTC (over 18 years ago)
What if you add 2b) save selection as channel? Then you can scale the image and reload the selection from the channel...
I may have misunderstood the question - let me know if this isn't helpful...
Chris
Anthony Ettinger
2006-12-08 00:51:34 UTC (over 18 years ago)
if i save selection to channel how will it be effected when I resize? ie - different radius on corners, or different aliasing? (I noticed this problem when I simply resized the image after it was rendered).
Chris
Chris Mohler
2006-12-08 00:58:32 UTC (over 18 years ago)
The channel is scaled with the image - I'm guessing (now) that you want to scale/skew the image and leave the selection intact?
Chris
Anthony Ettinger
2006-12-08 03:40:25 UTC (over 18 years ago)
Right, same rounded corners, just not as wide.
