paint tools and autoscroll
9 of 10 messages available
paint tools and autoscroll Sven Neumann 03 Dec 16:49
  paint tools and autoscroll Olivier Lecarme 03 Dec 16:55
   paint tools and autoscroll Sven Neumann 03 Dec 17:02
  paint tools and autoscroll Matthias Julius 03 Dec 16:57
  paint tools and autoscroll Jakub Steiner 03 Dec 18:52
mailman.1.1165176003.10774.... 07 Oct 20:18
  paint tools and autoscroll Ben Walker 04 Dec 17:03
   paint tools and autoscroll Michael Schumacher 04 Dec 18:05
    paint tools and autoscroll Ben Walker 05 Dec 17:17
   paint tools and autoscroll Sven Neumann 04 Dec 20:54
2006-12-03 16:49:04 UTC (over 18 years ago)
a user has expressed his opinion in Bugzilla that the autoscroll feature is more harmful than useful for paint tools:
Auto scroll for drag and drop, for moving a floating selection etc == all win and good. I just think it's a bad default action for freehand drawing tools, where bam, you get a line drawn all the way accross the screen. I have to stop, undo the drawing I just did hope it wasn't a full minute of trying to paint the edge of something or sketching a difficult body part in a wierd pose I just finally got right. Then pull my heart out of my throat if it's been an hour since my last save and the screen just scrolled 700 pixels down in half a second for no apparent reason.
It would be trivial to turn autoscrolling off for paint tools. But I wonder if other users find it useful. So, please let me know. Do you think the image view should scroll when you touch the edge of the window with a paint tool? Should this stay, should it be turned off in general or can we improve the behaviour for example by using a longer delay before autoscrolling starts?
Olivier Lecarme
2006-12-03 16:55:35 UTC (over 18 years ago)
I am of the same opinion as this user. I think that the autoscroll feature should at least offer the option of turning it off for painting tools, as the user finds it suitable. Using a tunable delay before starting it could be still better: if you prefer to turn it off, choose a practically infinite delay.
Matthias Julius
2006-12-03 16:57:06 UTC (over 18 years ago)
Sven Neumann writes:
Maybe you can make it a user setting.
Matthias
2006-12-03 17:02:53 UTC (over 18 years ago)
I'd like to avoid making it another choice in the preferences dialog. While you might want to turn it off for paint tools, you might want to keep it for other tools. In the end we will need to make it configurable per tool. I would prefer if we could find sane defaults that work for most users.
Jakub Steiner
2006-12-03 18:52:11 UTC (over 18 years ago)
Hi Sven,
I cannot imagine painting something sane while the view auto-scrolls. Not scrolling sounds sane for paint tools.
cheers
Ben Walker
2006-12-04 17:03:10 UTC (over 18 years ago)
I agree that normally autoscroll is not generally appropriate for painting. For drawing lines however, it could be very useful, if one knows exactly where one wants to begin and end a line. I do this type of graphic work all the time for web design, and normally have to do the line piecemeal as I often need to zoom in to place the line accurately.
Ben W.
2006-12-04 18:05:13 UTC (over 18 years ago)
Von: Ben Walker
You are talking about straight line, right? Then this can be handled by multiple views.
What is the difference between painting and drawing, btw? The paint tools don't auto-scroll in draw mode anyway (this is what you get by holding shift (aka "how to draw straight lines")).
Maybe you could explain in more detail how you work with scrolling to draw lines?
HTH, Michael
2006-12-04 20:54:37 UTC (over 18 years ago)
Use two views then. One zoomed in on the start point and one zoomed in on the end point.
Ben Walker
2006-12-05 17:17:13 UTC (over 18 years ago)
Michael Schumacher wrote:
Von: Ben Walker
[I should have sent this to the list, I was briefly confused and was responding to individuals rather than the list, after having turned off digest mode]
Sorry for the ambiguity; I suppose drawing is the correct term. GIMP doesn't presently autoscroll when "drawing," but that seems like much more useful behavior then autoscrolling while "painting" (i.e. using the paint tools without any modifier keys). Please notice the use of the word "could" in my original message. Notice also how I said I need to draw the line piecemeal since GIMP doesn't presently autoscroll in drawing mode as you have observed.
To restate: when "drawing" lines using the paint tools, it would be helpful if autoscroll was enabled. I agree with others, that enabling autoscrolll while "painting" with the paint tools is not especially useful in my experience. I don't use scrolling when drawing lines, I have had to draw, scroll, draw, scroll, etc...
My original post could have been clearer. I just tried using multiple views, and it works well. Thank you for the suggestion. I would not have anticipated this behavior, but it is useful.
Ben W.
