DNG Plugin for Gimp
DNG Plugin for Gimp Philipp Drechsler 31 Jul 10:04
  DNG Plugin for Gimp Mukund 31 Jul 14:37
  DNG Plugin for Gimp Mukund 31 Jul 14:40
Philipp Drechsler
2006-07-31 10:04:06 UTC (over 18 years ago)
DNG Plugin for Gimp
does somebody know, if there is a plan to develop a DNG Plugin to open DNGs in Gimp? Or is there still one existing?
Regards, Philipp
Mukund
2006-07-31 14:37:39 UTC (over 18 years ago)
DNG Plugin for Gimp
Strangely, Adobe's website lists GIMP as supporting DNG (read-only): http://www.adobe.com/products/dng/supporters.html
AFAIK there isn't _any_ specific support for it. It should be possible to hack something based on the TIFF plug-in, as DNG is based on TIFF. TIFF/EP actually. In fact that's why the TIFF plug-in opens the thumbnail image in the DNG file.
Quote: "Therefore, if the full-resolution image is stored using compression, the TIFF/EP file should include a thumbnail image stored in the 0th IFD that is readable by a baseline TIFF 6.0 reader. This thumbnail should not be compressed, and should be stored in strips, rather than in tiles, in order to be fully compatible with TIFF 6.0. A SubIFDs tag in the 0th IFD is used to point to the compressed full-resolution image. If the full-resolution image is stored uncompressed as a baseline-readable TIFF image, the full-resolution image could be stored in the 0th IFD. However, TIFF/EP recommends that a thumbnail image be stored in the 0th IFD, regardless of whether the full-resolution image is baseline TIFF readable or not. This provides a version of the image that is small (relative to the full-resolution image) and that may be quickly accessed by reader software."
Mukund
2006-07-31 14:40:18 UTC (over 18 years ago)
DNG Plugin for Gimp
Btw, the dcraw program seems to support DNG according to its webpages. So a GIMP plug-in for dcraw may be able to open it. Just guessing.
Mukund
