Error while running Gimp 2.2.12 on FC2
Error while running Gimp 2.2.12 on FC2 Prasanna Kumar K 25 Jul 07:53
  Error while running Gimp 2.2.12 on FC2 Sven Neumann 08 Aug 12:25
Prasanna Kumar K
2006-07-25 07:53:02 UTC (over 18 years ago)
I'm trying to run Gimp 2.2.12 over GTK-DirectFB. I'm able to run it by typing $ ./gimp-2.2 in command line. But I'm not getting the whole window (only partial window is visible and the buttons are also not visible). After closing the application I'm getting following messages.
[root@localhost bin]# ./gimp-2.2
---------------------- DirectFB v0.9.25
(c) 2000-2002 convergence integrated media GmbH
(c) 2002-2004 convergence GmbH
(*) DirectFB/Core: Single Application Core. (2006-07-25 05:01)
(*) Direct/Memcpy: Using MMXEXT optimized memcpy()
(*) Direct/Thread: Running 'VT Switcher' (CRITICAL, 18253)...
(*) Direct/Thread: Running 'Keyboard Input' (INPUT, 18262)...
(!!!) *** UNIMPLEMENTED [fusion_reactor_set_lock] ***
[reactor.c:853]
(*) DirectFB/Input: Keyboard 0.9 (convergence integrated media
GmbH)
(*) Direct/Thread: Running 'Linux Input' (INPUT, 18263)...
(*) DirectFB/Input: ImPS/2 Generic Wheel Mouse (1) 0.1
(convergence integrated media GmbH)
(*) Direct/Thread: Running 'Linux Input' (INPUT, 18264)...
(*) DirectFB/Input: AT Translated Set 2 keyboard (2) 0.1
(*) Direct/Thread: Running 'PS/2 Input' (INPUT, 18265)...
(*) DirectFB/Input: IMPS/2 Mouse 1.0 (Convergence GmbH)
(*) DirectFB/Genefx: MMX detected and enabled
(*) DirectFB/Graphics: MMX Software Rasterizer 0.6
(*) DirectFB/Core/WM: Default 0.2 (Convergence GmbH)
(!) DirectFB/FBDev: Panning display failed!
--> Invalid argument
(*) Direct/Thread: Running 'EventBufferFeed' (MESSAGING, 18266)...
(gimp-2.2:18250): Gdk-DirectFB-WARNING **:
gdk_window_set_keep_above() not implemented.
gdk_window_set_keep_below() not implemented.
Gdk-DirectFB-Message: unimplemented
(!!!) *** WARNING [Application exited without
deinitialization of DirectFB!] *** [core.c:741 in
dfb_core_deinit_check()]
Can anyone please sort this out.
I'm using following packages to rum Gimp.
Glib 2.12.0
ATK 1.10.1
DirectFB 0.9.25.1
Cairo 1.2.0
Pango 1.13.1
GTK 2.10.0
GIMP 2.2.12
Waiting for your replies..
Prasanna.
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s)and may contain confidential or privileged information. If you are not the intended recipient, please notify the sender or administrator@tataelxsi.co.in
2006-08-08 12:25:08 UTC (over 18 years ago)
Not sure if the DirectFB backend is ready to run such a complex application such as GIMP yet. Are you using the backend that comes with GTK+ 2.10? Anyway, you are better off asking these questions on the directfb-users list.
