draw simple and common shapes?
draw simple and common shapes? Senectus . 19 Jul 11:29
  draw simple and common shapes? Jakub Steiner 19 Jul 11:47
   draw simple and common shapes? Luc Novalès 20 Jul 08:48
Senectus .
2006-07-19 11:29:15 UTC (almost 19 years ago)
Can anyone point out to me if there is a plugin or script for drawing simple shapes like arrows or speech bubbles for GIMP ? I used to be able to pump these out of PSP very quickly, is that possible for GIMP, or will I have to create them by hand every time?
Thanks
Jakub Steiner
2006-07-19 11:47:26 UTC (almost 19 years ago)
Hi.
You'd be better off with doing these things in Inkscape[1], a vector illustrator. They have very nice tools for creating arrowheads and editable rounded rectangles. It sounds like a much better tool for the job you describe.
cheers
[1] http://www.inkscape.org
Luc Novalès
2006-07-20 08:48:53 UTC (almost 19 years ago)
Hi.
+1
and if you want use these shapes in Gimp, you can import them as paths.
Luc.
