Default quality for jpg file saving
Removing Background Tutorial Seth Burgess 13 Apr 04:12
  Removing Background Tutorial Bret Hughes 13 Apr 05:17
Removing Background Tutorial Nigel 14 Apr 06:29
Default quality for jpg file saving Florian Steiper 14 Jul 11:49
Seth Burgess
2002-04-13 04:12:35 UTC (about 23 years ago)
Since removing a background seems to becoming an FAQ, I whipped up a tutorial last night:
http://www.gimp.org/~sjburges/color_to_alpha/color2alpha.html
Happy GIMPing,
Seth Burgess sjburges@gimp.org
___
Bret Hughes
2002-04-13 05:17:49 UTC (about 23 years ago)
Happy GIMPing,
Outstanding tutorial. I had no idea that you could drag a color like that. HUGE tip for me.
Bret
Nigel
2002-04-14 06:29:49 UTC (about 23 years ago)
Step3: Right clicking on the white widget (or whatever its called) will allow windows users to select forground or background colours bypassing the need to set values manually.
Nigel ----- Original Message -----
To:
Sent: Saturday, April 13, 2002 2:12 PM Subject: [Gimp-user] Removing Background Tutorial
tutorial
last night:
Happy GIMPing,
___
Florian Steiper
2002-07-14 11:49:29 UTC (almost 23 years ago)
Hello
I've been wondering if you can set the default quality for the jpg filter somewhere in some configuration file, I have many many pictures here and I want to edit them (only cut them and maybe do a little color correction) and then save them again (I know that I am losing quality with jpeg..) and as there are many it gets old to change the picture quality to 97 every time I save an image.. last time I just compiled the jpeg plug-in and changed those settings in the source file, but I wonder if there is another place where you can change this..
Thanks in advance
Florian
