gif/avi in gap
gif/avi in gap adly mabro 28 May 09:07
  gif/avi in gap Carol Spears 28 May 12:10
adly mabro
2006-05-28 09:07:08 UTC (almost 19 years ago)
gif/avi in gap
Do I have to convert my gif animation to avi in order to get my layers into frames using "Split Video into Frames", or is there another way in gap, that is still automated?
Thanks,
Adly
__________________
Carol Spears
2006-05-28 12:10:44 UTC (almost 19 years ago)
gif/avi in gap
an animated gif is a image with color restrictions and is made of layers. an avi is an mp3 with encoding limitations and is made of frames.
you should first use gap to split the gif into separate images using /Video/Split image into frames and then re-encode into avi using /Video/Encode/Master videoencoder.
the default settings for the gap master encoder will produce an avi that has been reported to not be viewable on Windows. i don't know if that has changed. this caused me to change the encoding (on a recommendation) to ts format (found somewhere in the master videoencoder dialog).
good luck with that as there are apparently as many different video encodings as there are people in this world. and perhaps more as those people are allowed to change their minds and rethink the things they have done and written.
