help for scripts
help for scripts Alex Feldman 20 May 01:23
  help for scripts Alan Horkan 20 May 14:50
Alex Feldman
2006-05-20 01:23:33 UTC (almost 19 years ago)
help for scripts
This is probably a stupid question, but here goes...
Is there some sort of organized to way to find out how a script works, what it does, and how to use it? Mostly I just use a combination of google searches, source diving, and blind experiment to try to figure these things out, but it's an imperfect system, particular as regards knowing what might be out there.
Thanks.
Alan Horkan
2006-05-20 14:50:46 UTC (almost 19 years ago)
help for scripts
On Fri, 19 May 2006, Alex Feldman wrote:
Date: Fri, 19 May 2006 17:23:33 -0600 From: Alex Feldman
To: gimp-user@lists.XCF.Berkeley.EDU Subject: [Gimp-user] help for scripts
Try the PDB Browser. You can find it in the toolbox menus. I'd love to see it moved into the same menus as the scripts though.
