eps images that won't load
eps images that won't load gurra16@spray.se 05 Apr 18:08
  eps images that won't load Niklas 06 Apr 01:15
   eps images that won't load John Culleton 06 Apr 02:32
   eps images that won't load Patrick 06 Apr 04:03
eps images that won't load] Carol Spears 06 Apr 22:59
eps images that won't load Carol Spears 07 Apr 22:44
gurra16@spray.se
2002-04-05 18:08:26 UTC (about 23 years ago)
How come GIMP fails to load these images? (Note they are zip-ed) http://www.liljeholmstorget.nu/press.html
Gustav Persson
_________________________________________s_p_r_a_y_ Här börjar Internet!
Skaffa gratis e-mail och gratis Internet på http://www.spray.se
Tävla och vinn med nya Coca-Cola Light i årets roligaste Quiz! http://quiz.spray.se/cocacola
Niklas
2002-04-06 01:15:38 UTC (about 23 years ago)
Hey...
Because it is a .eps file and GIMP don't have support for that what it seems like.
Don't even know what a .eps file is really but it seems to not be supported by GIMP.
//Niklas
Gustav Persson
John Culleton
2002-04-06 02:32:09 UTC (about 23 years ago)
On Friday 05 April 2002 18:15, Niklas wrote:
Hey...
//Niklas
EPS means Encapsulated PostScript'' and you should be able to load it into Gimp. Gimp produces such files when needed.
John Culleton
Patrick
2002-04-06 04:03:54 UTC (about 23 years ago)
On Friday 05 April 2002 06:15 pm, Niklas, was heard saying:
Hey...
//Niklas
Gimp may not load postscript graphics files, I know I have not tried them yet. The file type .eps is encapsulated postscript and not many graphics programs do load them. Usually require some structured art program rather than bitmap type.
Patrick
Carol Spears
2002-04-06 22:59:56 UTC (about 23 years ago)
hi Peter,
here is what the big guys said ...
good luck! carol
----- Forwarded message from Peter Kirchgessner -----
CC: gimp-developer@lists.xcf.berkeley.edu, gurra16@spray.se Subject: Re: [Gimp-developer] Re: [Gimp-user] eps images that won't load Date: Sat, 06 Apr 2002 21:57:42
Hi Carol,
EPS-files require an additional showpage command submitted to ghostscript. This is usually done by the ps-plugin. But these binary PostScript files (I have never seen before) are not recognized as EPS-files. The plug-in is not looking at the extension. If you or Gustav are working with Linux, you can use a workaround. Create a file /tmp/gs_eps with the following content:
#!/bin/sh args=`echo $* | sed -e 's/eps -c quit/eps -c showpage -c quit/'` exec gs $args
(Note the different ` and ?). Make it executable:
chmod 755 /tmp/gs_eps
Set an environment variable in the bash:
export GS_PROG=/tmp/gs_eps
and start gimp from that shell:
gimp TORG_illustration.eps
For Windows I don't know an appropriate workaround.
Sincerely
Peter
Carol Spears wrote:
here is a question from the user list. since i have used gimp to work with eps files before, i got one of the images and tried to open it. my gimp-1.2 failed also. any ideas?
the image i downloaded and unzipped is located here http://carol.gimp.org/files/TORG_illustration.eps
thanks, carol
On 2002-04-05 at 1808.26 +0000, gurra16@spray.se typed this mail:
Gustav Persson
Gimp-developer@lists.xcf.berkeley.edu http://lists.xcf.berkeley.edu/mailman/listinfo/gimp-developer
Carol Spears
2002-04-07 22:44:12 UTC (about 23 years ago)
hmm, pretty quick huh?
this guy also wrote alot of my favorite plug-ins. poking around his web site, i was wondering how many collections of photos there were out there that people had made with photo mosaic in mind.
once i tried to make a fake batch of photo mosaic ready photos by making about one hundred or so into darkened and lightend grey scale images. unfortunately, those are long gone.
sorry to ramble ... carol
CC: gimp-developer@lists.xcf.berkeley.edu Subject: Re: [Gimp-developer] Re: [Gimp-user] eps images that won't load Date: Sun, 07 Apr 2002 18:07:15 +0200
the corrected plug-in is available in source and executable for Linux/i386 at http://www.kirchgessner.net
Sincerely
Peter
Carol Spears wrote:
On 2002-04-06 at 2157.42 +0200, Peter Kirchgessner typed this mail:
Hi Carol,
