Easily converting "grey colors" to another single color?
Easily converting "grey colors" to another single color? supraexpress@globaleyes.net 13 Jul 03:08
  Easily converting "grey colors" to another single color? Andreas Waechter 13 Jul 07:20
  Easily converting "grey colors" to another single color? Sven Neumann 15 Jul 19:49
2005-07-13 03:08:45 UTC (almost 20 years ago)
Is there a (relatively) easy way to convert/exchange a large number of close RGB-valued "grey colors" to one single color? This is relevant to an image with "up to 255 shades of grey", or black, or ....
In other words, is there a way to convert or exchange a "range of color" whose RGB values are close to each other, say within 1-5% (as shown by Color Picker), varying from, say, 71-121 (in the Color Wheel). I have used Color Exchange a lot, but that only works on one "shade value" at a time.
Andreas Waechter
2005-07-13 07:20:34 UTC (almost 20 years ago)
Have you tried "Select by Color" with a threshold value greater than 0 to select the grey tones and then "Fill" with the replacement color?
Andreas
2005-07-15 19:49:55 UTC (almost 20 years ago)
supraexpress@globaleyes.net writes:
That's what Posterize is meant to be used for, isn't it?
