Clone tool issues
Clone tool issues Crossover 24 Sep 07:41
  Clone tool issues rich404 24 Sep 09:55
   Clone tool issues Crossover 24 Sep 11:29
  Clone tool issues AlexCrombie 22 Jan 11:19
2020-09-24 07:41:09 UTC (over 4 years ago)
Clone tool issues
My clone tool seems to be dancing. When i click on a particular brush shape & then i try to use it on the opened image... the size & the angles of the clone tool-is constantly changing as i move or hover it around the image. Example -the round brush tool goes elliptical, the rectangular brush tool increases or decreases in size, it constantly changing angles etc .... i am going nuts trying to figure this out, Please help ...
2020-09-24 09:55:13 UTC (over 4 years ago)
Clone tool issues
Best guess, you have a dynamic option in force. Might be Confetti or Random. Turn it off in Clone tool options, set "Dynamics Off" as the screenshot.
If you are also using a graphics tablet, then 1) by default there are separate settings for mouse and tablet 2) Some extra dynamics come into play, pressure-size or speed-size for example.
2020-09-24 11:29:07 UTC (over 4 years ago)
Clone tool issues
Thanks mate, You nailed it. My issue has been resolved.. Thanks a ton....!
Thanks & Regards, Selvaraj.K
2021-01-22 11:19:40 UTC (about 4 years ago)
Clone tool issues
According to the political and general inform formation point of view thus the blog is perfect to read and get updates. I truly appreciate the for sharing this with us. So that we can have the best to deal with all the contents and students can check [url=https://edubirdie.net/]edubirdie[/url] services to manage the task. I have read this article and it this amazing enough.
