Trouble getting GIMP to work - occasionally
Trouble getting GIMP to work - occasionally John Noir Smith via gimp-user-list 20 May 06:37
  Trouble getting GIMP to work - occasionally IolaNorman 31 Dec 06:16
2020-05-20 06:37:21 UTC (almost 5 years ago)
I think it may be more fair to say that it work's occasionally, and most of the time it doesn't.
I'm using a MacBook Air, which I know isn't optimal for GIMP, and I have the latest version available for MacOS (GIMP 2.10.14).
What happens is I open up GIMP, and try and start a project - and most of the times it will at least open up the picture I mean to work with, or start a blank canvas if I ask for it - but it won't let me select any tools, and whatever I try to do to the picture using the toolbar at the top of my window won't do anything either. Like I can for instance open up Colors -> Brightness-Contrast, but it won't do anything to the image even if I go to 100.
I'm not sure how to search for this issue, so I figured in the end it would be better to try and make a post of my own. I've tried to delete and reinstall it a couple of times, but it's an issue which just keep recurring.
Thanks for your help in advance! -John
2021-12-31 06:16:56 UTC (over 3 years ago)
The trouble here is about getting the GIMP to work occasionally in the variation of help and the support. The discussion is basically connected with it and https://www.australian-writings.org/ that are having the trouble in the using of command and other sense of suitability in life.
