Neophyte questions
Neophyte questions Adobero 12 Apr 21:01
  Neophyte questions Ofnuts 13 Apr 09:28
2020-04-12 21:01:09 UTC (about 5 years ago)
Neophyte questions
Attempting to migrate from PS to GIMP. In PS I learned > Cut to New Layer in ~10 seconds, used it in 2 seconds. In GIMP I'm wasting far too much time... Help! I attempted about X00 times to Rectangular Select > Cut a historic photo image from it's antique border and paste it onto a new layer. After ~X00 attempts, I was still unable to enjoy my selection surrounded by 'marching ants'. After far too many hours, I stumbled into an unrelated GIMP forum unrelated conversation that included "Do a Select > None." So after .5 lifetimes, I tried that and somehow rectangular 'marching ants' appeared. What does Select > None have to do with anything? How do I determine what is / is not on my clipboard?
Cut to New Layer was (if that's possible) much worse. Of course I tried creating a new layer and Cut > Paste to it. I tried letting various flavors of Paste create a new layer. This, I guess sporadically produced a worthless 'Floating Layer'. What does a Floating Layer have to do with anything? I tried anchoring everything to everything including my forehead. Sometimes the Anchor Button disappeared for a month. What does anchoring have to do with anything?
But even more delightful (if that's possible), the Edit > Cut choice goes dark for a month. This, of course, allows zero cutting until I revert to an earlier version of my work from a few months earlier. What are advantages of Edit > Cut going dark? Did I breach my Edit > Cut limit? Did I fail cutting too many times? Just curious.
And what else could I stumble into that could possibly make GIMP even more unproductive than I describe above? Well, after about 85,623 attempts to Select
Cut > Paste, I observe the following:
(1) Zero pixels from my original Selection ever disappeared from my source layer; My source layer has no 'hole' in it, as I expect from a 'Cut'. (2) Zero pixels from my original Selection ever appeared on my new target layer; My new target layer has zero pixels or material from my source layer via 'Cut > Paste'.
Does GIMP Help help? Apparently not. If Help helped, I would not have written this sorry saga.
Thank you for your help in this matter,
Adobero lschell88@gmail.com
Adobero (via www.gimpusers.com/forums)
2020-04-13 09:28:31 UTC (about 5 years ago)
Neophyte questions
So you have to "unlearn" PS. Gimp is not a PS clone, it is a different editor with its own ways.
You could have the Selection tool in a mode other than "Normal" (for instance, "Intersect"), or you just didn't have the selection visible (View>Show selection or Ctrl-T, you can also use Windows>Dockable dialogs>Selection editor to see you current selection). Seeing a "forbidden" icon near the pointer is also an indication.
This "Floating selection" is your copy... One reason it works that way is to let you adjust the copied stuff before your merge it (in particular, move/scale/rotate). After this you have two choices:
- Merge it (the term is "anchor") to your target layer: Layer>Anchor layer, Ctr-H, or the Anchor button at the bottom of the Layers list
- Make it a layer of its own: Layer>To new layer, Ctrl-Shift-N, or the "New layer" button at the bottom of the Layers list
You have to do either action before you can do other things (many menus will be disabled while there is a floating selection).
There are case swhere you can't cut: no selection, no pixels in the selection in the current layer...
You get a hole if your layer can be transparent. If it is not you can make it so using "Layer>Transparency>Add alpha channel". If you load and image from a format that doesn't support transparency you won't get an alpha channel by default. If there is no alpha channel, the cut is filled with the background color (this is also how the erase behaves...). Hint: the name of layers with no alpha channel is in boldface in the Layers list.
Yes, because it is all in the Floating Selection that you disregarded.
